Durga Puja
01Day 17Hr 00Min 17Sec
Durga Puja
download products
Viewing 6 reply threads
    • #122074
      nakedharmonix
      I need to disable the “require” in the WCFM download product settings.
      What can I do?
      Regards,
      TK
    • #122075
      nakedharmonix
      This field.
    • #122156
      Keymaster
      Hi
      Use the following snippet to do so-
      add_filter( 'wcfm_product_fields_downloadable', function($downloadable_fields) {
          if ( isset( $downloadable_fields['downloadable_files']['options']['name'] ) ) {
              unset( $downloadable_fields['downloadable_files']['options']['name']['custom_attributes']['required'] );
          if ( isset( $downloadable_fields['downloadable_files']['options']['file'] ) ) {
              unset( $downloadable_fields['downloadable_files']['options']['file']['custom_attributes']['required'] );
          return $downloadable_fields;
      Let me know how it goes.
    • #122228
      nakedharmonix
      Thank you for your quick response.
      However, I am asked to fill in the shipping address on payment, even though I have checked “Download” in the product settings.
    • #122410
      Keymaster
      Take a look at this plugin – https://wordpress.org/plugins/woo-checkout-for-digital-goods/
      From its description it seems like, it can be helpful for your purpose.
      Thank You!
    • #122729
      nakedharmonix
      Thank you for your quick response!
      The order status of the virtual product stops in Processing.
      Is there a solution to this problem?
    • #122845
      Keymaster
      There is a plugin that can autocomplete orders – https://wordpress.org/plugins/autocomplete-woocommerce-orders/
      Give it a try and see if that is what you want.
  • The topic ‘download products’ is closed to new replies.
