wcfm-santa
Wishing you joy this Diwali and Halloween! Enjoy up to 20% off on all addons!
02Day 20Hr 09Min 37Sec
wcfm-santa
Download products and licensing
Viewing 8 reply threads
    • #11361
      Katie
      Re WP forum – Having a look at the ultimate plugin for downloads.
      However we require a licensing option for downloads. (which we already use)
      ie: one license X$ more than one at Y or Z price to be available in the frontend product creation and description.
      Does not seem that you have this option.
    • #11363
      WCfM Forum
      That can be achive easily by creating Veriable-Downloadable product.
      Please try that at any of our demos.
    • #11384
      Katie
      Hi again. yes tested that as a fallback (variable is not quite the same as Licensing although we could make use of it in this instance)
      however when choosing Download as the option – no variables are available.
    • #11385
      Katie
      _The only option that shows the Download or Virtual product is SIMPLE product
      the other options do not show Download or Virtual
      Is that an oversight on the demo ?
    • #11386
      Kindly check this Product:
      http://wcmp.wclovers.com/wc_frontend_manager/wcfm-products-manage/259/
      Hope this will work for you.
    • #11389
      Katie
      Yes that is what i was using to assess.
      There is no option for Download product as noted above.
      Cannot attach a graphic here but if you use your test site, you will see there is no option
    • #11390
      WCfM Forum
      Sorry can’t get you exactly.
      Did you check that test product and is it meet your requirement?
      Please check the Atrributes and Variations tab of that product.
      Your requirement can be possible using Variable-Downloadable product, but not just using Simple-Downloadable product.
      As I already mention you before, Downloadable and Variable-Downloadable product is part of WCfM Ultimate Version.
      Where you want to attach grafics?
      You can add Image for separate Variations.
    • #11396
      Katie
      If you test using your own test site that you gave a link to.
      There is no option for download products other than “simple”
      I would attach a graphic here to show you but I cannot.
      So if you go to your own test site, you will see that only Simple products have the option for “download”
      No other product option has the download or virtual option
    • #11397
      WCfM Forum
      Ok, now I understand your query.
      Actually WooCommerce works in such a way.
      If you check wp-admin add prodct page, you will experience the same.
      I am also explaning why this:
      1. For simple product you can define that as Downloadable so it has the option
      2. For variable product you will get downloadable option under each variation
      3. External and Grouped product can not be defind as Downloadable
      Hope you understand … if you still have any further query please feel free share with us.
  • The topic ‘Download products and licensing’ is closed to new replies.
