Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Downloadable products: multiple upload
- This topic has 3 replies, 2 voices, and was last updated 5 years, 6 months ago by
Sarmistha Chakraborty.
- April 16, 2020 at 6:21 pm #119770
martin gomez
ParticipantHi, I need to allow multiple files upload to downloadable products from mobile. Is this possible? Also, the name can be autocompleted with the file name?
Thanks! - April 17, 2020 at 12:13 pm #119955
>> Can you explain us what is the meaning of “from mobile” ? Do you want from “mobile app” or “your site in mobile device”?
Vendor have the capability to upload multiple files for downloadable product(PFA). Please clarify.Thanks.
You must be logged in to view attached files. - April 21, 2020 at 6:12 am #121205
martin gomez
Participantyes, i see that option. I have vendors that have to upload 30 images for example and its tedious to upload 30 files with the plus button. Maybe there is a way to upload the 30 files and select all the files. From mobile i mean: using my web from a mobile phone(not the app).
I need to upload multiple files at once.Also i need the autocomplete name for the files.
- April 21, 2020 at 9:01 pm #121448
As you know WooCommerce also works this way.
This requirement is need good amount of customization not any tweak work.
If you want that customization work Please contact us here for the purpose – https://wclovers.com/woocommerce-multivendor-customization/ with your requirement.Thanks.
