Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › duplicate product option is not working
- This topic has 26 replies, 3 voices, and was last updated 7 years, 6 months ago by
- February 24, 2018 at 7:44 pm #19430
Sheikh Md Osmani
ParticipantAfter 2nd last update the duplicate button is not working. The page is being loaded infinitely after clicking on the duplicate button. My site is a the url http://bit.ly/2EQL58Q.
Please help me to solve the issue ASAP.
- February 24, 2018 at 7:51 pm #19432
Simha
I am really sorry for the inconveniences.
Hope your wcfm and wcfm ultimate both are at latest version.
We are just looking into this issue asap.
- February 24, 2018 at 8:01 pm #19433
Sheikh Md Osmani
ParticipantThis reply has been marked as private. - February 25, 2018 at 3:11 pm #19445
MemberThis is quite strange, we have just added this option in WCFM 3.5.4 and it works.
is there any caching in your site ?
Can you also please check once Vendor settings page browser console, if there is any error or not?
You may check this at our demo but no such issues – http://wcmp.wcfmdemos.com/my-account
- February 25, 2018 at 3:57 pm #19446
I have tried many way but can’t able to generate any of these issues in our environment.
You may test both at our demo, running on WCMp 3.0 – http://wcmp.wcfmdemos.com/my-account
I think, there has some other errors in your site. Can you please check WooCommerce -> Status -> Logs for the purpose, or server PHP log will be also helpful.
- February 26, 2018 at 7:51 pm #19464
Sheikh Md Osmani
ParticipantThis reply has been marked as private. - February 26, 2018 at 8:02 pm #19465
Did you checked WC logs yet?
Hope you also tried at our demo site, are you facing the same?
Can you share me a demo vendor access to check the things once!
- February 26, 2018 at 8:16 pm #19467
Sheikh Md Osmani
ParticipantThis reply has been marked as private. - February 26, 2018 at 8:46 pm #19468
MemberThanks for the credentials.
Can you please know me site wp-admin and WCFM dashboard URL?
- February 26, 2018 at 8:54 pm #19470
Sheikh Md Osmani
ParticipantThis reply has been marked as private. - February 26, 2018 at 9:25 pm #19472
I have just checked and found that your site is throwing 500 internal server error.
Can you please enable WP_DEBUG to check why this error is generating?
- February 26, 2018 at 9:36 pm #19473
Sheikh Md Osmani
ParticipantThis reply has been marked as private. - February 26, 2018 at 9:44 pm #19475
MemberYeah sure.
- February 26, 2018 at 9:51 pm #19476
Well, this time after login it takes me directly to the WCFM Dashboard.
But 500 error is still there.
- February 26, 2018 at 10:01 pm #19484
WCFM a new version will be there in few minutes.
We will debug this again after the new version.
Please know me when you your update done, and be sure cache should be cleared.
- February 26, 2018 at 10:02 pm #19485
Sheikh Md Osmani
ParticipantBut from my side I can login without any error.
- February 26, 2018 at 10:04 pm #19486
I also can login and visit WCFM dashboard as well.
I am getting 500 error when try to “Duplicate” a product.
Can you enable “WP_DEBUG” to check the actual error.
- February 26, 2018 at 10:19 pm #19487
Sheikh Md Osmani
ParticipantI have enabled. There is no error , only two notices.
- February 26, 2018 at 10:27 pm #19489
MemberWCFM new version is there, kindly update yours.
I am checking this.
- February 26, 2018 at 10:30 pm #19491
Sheikh Md Osmani
ParticipantI have already updated to the latest version you just launched.
- February 26, 2018 at 10:54 pm #19492
MemberThanks.
Is this possible to disable cache for sometime?
With caching I can’t get any trace in HTML! - February 26, 2018 at 10:59 pm #19493
Sheikh Md Osmani
ParticipantThis reply has been marked as private. - February 26, 2018 at 11:00 pm #19494
MemberAs I found, your site’s CSS/JS are also minified, that also cleaned?
- February 26, 2018 at 11:01 pm #19495
Sheikh Md Osmani
ParticipantThis reply has been marked as private. - February 26, 2018 at 11:07 pm #19496
MemberBut it stills loading old files.
https://www.dokanmela.com/dokanmela_components/module22/assets/js/wcfm-script-settings.js
This is not from latest WCFM 3.5.5
May be it will take some time to load new files.
- February 26, 2018 at 11:15 pm #19497
Sheikh Md Osmani
ParticipantThis reply has been marked as private. - February 26, 2018 at 11:21 pm #19498
MemberYeah, now it’s refreshed.
Just check, Settings -> Brand -> Map is now working perfectly.
Can you please enable WP_DEBUG now, hope it’s again set OFF.
Thanks for your all the efforts.
- The topic ‘duplicate product option is not working’ is closed to new replies.
