Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Earnings – when applying coupon vendor earning is not well calculated
- This topic has 5 replies, 3 voices, and was last updated 6 years, 5 months ago by
- March 21, 2019 at 7:46 pm #53875
Alexandru
GuestHello guys,
A vendor created a coupon, let’s say 50% discount. A client uses this coupon and buys a product.
Vendor sees in orders that he gain the total amount of money not 50% less.Please fix this!
Alexandru
- March 22, 2019 at 11:21 am #53987
Please be sure, you have this option enabled at WCFM Admin Setting -> Commission Setting – https://ibb.co/mX2CGLd
- March 22, 2019 at 11:23 am #53988
MemberBetween, if you have setup commission at membership or vendor level then check there as well.
- March 22, 2019 at 1:33 pm #54002
Jose
It’s true, something happend with the last update.
I have one case with coupon discount (20%) of vendor and all gross total come to vendor like commission.
I have other case without coupon and the commission are not only the % that we put.With differents setting in commissions happend the same.
Example: (80% commission to vendor, and shipping cost to vendor) Whithout coupon discount.
Product $ 15000
Shipping: $ 3800
Total: $ 18800The system show $ 15800 like commission to vendor (Wrong) in order and leadger !!
Commission need to be $ 12000Please, can you check with different situations ?
Regards,
- March 22, 2019 at 2:51 pm #54024
Jose
Update !
Ok, with normal buy is correct, vendor receive $ 15800. But exist a confussion about terms.
Show just commission is a mistake because is a withdrawal (commission + shipping cost) like setting was made.Sorry for my fault !
Regards
- March 23, 2019 at 1:11 pm #54207
MemberNO worries, thanks for the update!
- The topic ‘Earnings – when applying coupon vendor earning is not well calculated’ is closed to new replies.
