Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Editing Vendor Banners and Logos
- This topic has 3 replies, 3 voices, and was last updated 5 years, 8 months ago by
- November 1, 2019 at 10:17 pm #90161
James Simone
ParticipantHi – for some reason, vendors can’t edit banners or logos – instead they are presented with an “X” where a file upload/selection should likely be.
For clarity:
1. The wizard allows initial upload
2. Editing the banner/logo post-wizard is the challenge.
3. User is set as ‘Vendor’ in the WP dashboard.
4. Capabilities (‘Settings Inside’) are set to allow logo and banner (set to green)Attachments:
You must be logged in to view attached files. - November 6, 2019 at 4:19 pm #91101
Also check in Google Chrome Browser console, is there any JavaScript error happening to the site or not! (What is browser console – https://support.airtable.com/hc/en-us/articles/232313848-How-to-open-the-developer-console)
You may also share your site access here – https://wclovers.com/woocommerce-multivendor-customization/
We will debug this for you.Thank You
- November 20, 2019 at 2:03 am #93022
aisaac92
ParticipantHi James,
Did you find a solution to this problem? I too have had this issue for the past couple of weeks and can’t find a fix for it.
- November 23, 2019 at 11:16 am #93559
MemberWell, this issue is specific to your site/ possibly due to theme.
If you are not getting any error then please contact us here – https://wclovers.com/woocommerce-multivendor-customization/
We will debug this for you and will fix.
- The topic ‘Editing Vendor Banners and Logos’ is closed to new replies.
