01Day 07Hr 52Min 33Sec
Elementor 404 template not working with WCFM
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Elementor 404 template not working with WCFM
Viewing 2 reply threads
    • #115053
      richard-9608
      When using the Elementor 404 catch all template, it isn’t compatible with WCFM. It thinks the store pages are 404 pages. I raised this with Elementor support and they stated the following:
      I have just checked the page you have shared as an example and I see, that there is the “error404” HTML class added on it, that’s why Elementor take it as a 404 page – http://prntscr.com/rrti0e
      You can contact the plugin developers or support team and let them know that this HTML class is presented on the plugin pages so they can suggest any fix for this.
      Once this CSS class will be removed, Elementor won’t apply its 404 templates for those pages.
    • #115281
      Well, it’s not possible to edit dashboard template using Elementor. in fact if you edit dashboard page template using Elementor it will generate error or you will get 404 error.
      Do you have edited “Store Manager” page template using Elementor?
      WCFM – Elementor (https://wordpress.org/plugins/wc-frontend-manager-elementor/) addon only support store page custom template using Elementor.
    • #134532
      deon
      I am using Elementor. WCFM backend dashboard does not work at all. When clicking on Marketplace menu item it takes me to home page.
  • The topic ‘Elementor 404 template not working with WCFM’ is closed to new replies.
