Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Email setting
- This topic has 13 replies, 2 voices, and was last updated 6 years, 9 months ago by
- October 2, 2018 at 8:10 pm #33081
wwsAdmin
ParticipantHi team,
Can you tell me what all are email send to vendor ?
WC Marketplace had wide range of emails, am not able to find any in WCFM Marketplace, WP-Dashboard-> Woocommerce-> Settings -> Emails.
Where as under WCFM Admin Dashboard -> Settings -> Notification Manager various option for emails under Vendor Notification. But vendor is not getting emails for new order. Can you explain how to customize them as well.
Shubhamsv - October 3, 2018 at 4:16 am #33122
“But vendor is not getting emails for new order. ”
– Not the notification as well!
Not even this type notification – https://ibb.co/hMMQGzThank you
- October 3, 2018 at 4:42 am #33131
wwsAdmin
ParticipantHi, this kind of notifications are working.
But u was looking for emails which was in WC market
- October 4, 2018 at 2:48 pm #33274
WCFM Marketplace 1.1.3 version just released.
We have added vendor new order email template there.
Membership / vendor registration email settings are already there in membership setting page.
- October 4, 2018 at 6:48 pm #33303
wwsAdmin
Sounds great will have alook.
Thanks alot
- October 4, 2018 at 7:35 pm #33312
wwsAdmin
Just like Earning, can you add Commission as well ?
Along with SKU can you Add product Name also?
- October 5, 2018 at 5:18 pm #33365
wwsAdmin
Participanthi,
Sample template below:
Store Name: BATLIWALA KRAFT
Product Title: HANGING PLANTER CC-44 (If possible linked to product and thumbnail)
SKU: 8664
Order date: 27 September 2018
Commission : Rs. 60.00
Your Earnings: Rs. 740
Total Order: Rs. 800
it might give clear idea to vendor
thanks - October 6, 2018 at 10:56 am #33408
Vendor Email template look like this – https://ibb.co/b4SWye
Everything is already there. It’s similar to vendor’s order details screen.
- October 6, 2018 at 11:40 am #33413
wwsAdmin
ParticipantThis reply has been marked as private. - October 6, 2018 at 11:58 am #33418
Yeah right, this is the vendor order email, added in latest update.
Your product name is “check”, don’t get confuse with that 🙂
- October 6, 2018 at 5:17 pm #33434
wwsAdmin
ParticipantHI,
Yes i know its Check 😉
Can you add hyperlink to it. Like WCMP used to do it along with thumbnail.
And earning is bit confused
thanks
- October 6, 2018 at 7:43 pm #33458
“Can you add hyperlink to it. ” – Product title, right? will add in next update.
“And earning is bit confused” – what you want to say this? If you will use “Admin commission mode” then it will come as “Fees”.
- October 7, 2018 at 11:29 am #33491
- October 8, 2018 at 7:20 am #33525
Umm … checked as vendor login and it’s showing right – https://ibb.co/cqEpM9
Are you still getting “earning” in vendor order emails?
- The topic ‘Email setting’ is closed to new replies.
