Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Email to Vendor when add Product
- This topic has 10 replies, 2 voices, and was last updated 7 years, 1 month ago by
- July 1, 2019 at 9:30 am #70497
thiemann.k
ParticipantHey Community,
what do i have to do (for example with a snippet) that all sellers get an email when a product in category (cat-id=228) has been added?
Members can submit a “Product Inquiry”. These all come in a single category. I would like to inform the sellers if a new product has been created here.
Best regards!
Karsten - July 4, 2019 at 5:15 am #70931
– You mean, if Admin add a product in this category then all vendors will be notified?
– Sorry, not getting this clearly.
- July 10, 2019 at 4:40 am #71769
thiemann.k
Participant– You mean, if Admin add a product in this category then all vendors will be notified?
– no…
I have a category where product inquiries come in. if a seller has this product, or can create, then he can respond to it.
Now I would like all Vendors to always receive an email or a notification when a product is added in category “228”.is that possible?
- July 13, 2019 at 7:44 am #72255
Well, vendors are by default notified if any inquiry comes for their products!
Do you want to disable this and only allow notification for this particular category products?
- July 17, 2019 at 4:27 am #72733
thiemann.k
Participantno, I do not want to =)
So:
I have a category where users can create “product requests”.
A customer is looking for a product that is not yet available in the shop, this can create its own product (Add User Product)
The user product automatically comes in a specified category (cat-id = “228”)
Now I would like an email / referrals (preferably both) to be sent to all sellers when a new product is created in this category. - July 18, 2019 at 12:08 pm #72943
Thanks for the details. I understand your concept.
– Do you have implemented this yet!
- July 18, 2019 at 2:01 pm #72974
thiemann.k
Participanthey =)
yes, I have already implemented that.
there are some plugins that implement that … which I like the most is the Add product frontend by NSThemes.Maybe you can offer something like that in the future? I think that is a good thing.
YES !
And now, when a customer has create his own product, than all vendors should be an notification/or email (maybe both).
but how does it continue?
a snippet should certainly implement this.
but how? - July 19, 2019 at 12:46 pm #73085
but how does it continue?– Well, that can be implemented easily.
Do you have any idea about this plugin’s coding?
Actually, I want to know, is there any hook after completing the product creating by this form!
- July 19, 2019 at 4:17 pm #73104
thiemann.k
Participantnot yet. is that necessary?
- July 20, 2019 at 5:02 am #73149
Yeah, as we have to write custom code to send out emails based on that hook.
Otherwise, we have to edit that plugin, and this is not good at any situation!
Can you please share your site access with me here – https://wclovers.com/woocommerce-multivendor-customization/
I will take a look at this.Thank You
- August 2, 2019 at 11:03 am #74830
Here is your code for the purpose –
add_action( 'wp_insert_post', function( $post_ID, $post, $update ) { global $WCFM; if( isset( $_POST["ns-product-name"] ) ) { $wcfm_messages = 'New product added to the site - <a href="' . get_permalink( $post_ID ) . '">' . get_the_title( $post_ID ) . '</a>'; $all_vendors = $WCFM->wcfm_vendor_support->wcfm_get_vendor_list( true, '', '', '', '', false ); if( !empty( $all_vendors ) ) { foreach( $all_vendors as $vendor_id => $all_vendor ) { if( $vendor_id ) { $WCFM->wcfm_notification->wcfm_send_direct_message( -1, $vendor_id, 1, 0, $wcfm_messages, 'new_product', true ); } } } } }, 50, 3 );Thank You
- The topic ‘Email to Vendor when add Product’ is closed to new replies.
