Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Enable all attributes by default
- This topic has 7 replies, 2 voices, and was last updated 5 years, 8 months ago by
- October 22, 2019 at 11:43 am #88207
coderunknown
ParticipantHello and really awesome plugin by you guys. Can you please help me archive the following: I need all the attributes to be active (& expanded) like shown in this pic. Right now one has to click the active box for each product which soon becomes an headache:
Can you guys provide some code/filter to pull it off? Even better if the active checkbox is also hidden. I tried a solution back from 2018 but the filter name changed and when I tried porting the solution, it won’t work in latest WCFM. I tried a few other solution like removing the JS trigger but that just broke the tab part. Really appreciate any kind of help.
Also I may have found a bug: wcfm-view-products-manage-tabs.php template is not overrideable. I even copied the entire products-manager folder just to be sure that the tabs file is not dependent on other template yet it won’t work. Other templates from enquiry or products folder overrides just fine.
And finally a big request: If possible in future please format the plugin code. VSCode/Sublime Text shows massive gap in the code. I had to manually format the plugin every time it updates.
- October 23, 2019 at 2:54 pm #88555
Please check this code snippet – https://docs.wclovers.com/tweaks/#set-attributes-required
Using this we have set Attributes as required field for product.
- October 23, 2019 at 8:32 pm #88678
coderunknown
ParticipantI think you misinterpreted my question. What I am trying to achieve is all attributes to be active i.e. Have the “Active?” box ticked and the attribute console expanded so client won’t have to manually activate each attribute for every product. I am still trying to achieve this from my end but if you guys can offer some kind of help, will be really wonderful.
- November 5, 2019 at 4:57 pm #90781
MemberOK, so you want to activate all attributes for all products?
- November 5, 2019 at 5:35 pm #90798
coderunknown
ParticipantYes, all attributes need to be active for all products. Because the site will host only 1 type of products (used cars).
- November 11, 2019 at 5:10 pm #91803
add_filter( 'wcfm_product_custom_attributes', function( $taxonomy_fields, $att_taxonomy ) { if( isset( $taxonomy_fields[$att_taxonomy] ) && isset( $taxonomy_fields[$att_taxonomy]['value'] ) ) { $attributes = $taxonomy_fields[$att_taxonomy]['value']; $wcfm_attributes = array(); if( !empty( $attributes ) ) { foreach( $attributes as $acnt => $wcfm_attribute ) { $wcfm_attributes[$acnt] = $wcfm_attribute; $wcfm_attributes[$acnt]['is_active'] = 'enable'; $wcfm_attributes[$acnt]['is_visible'] = 'enable'; } } $taxonomy_fields[$att_taxonomy]['value'] = $wcfm_attributes; } return $taxonomy_fields; }, 50, 2);
- November 14, 2019 at 12:33 am #92201
coderunknown
ParticipantTYSM for the code. Now I realized where I made the error. Instead of looping through all the attributes, I tried to bruteforce the ‘enable’ values to all attributes at once. Obviously it didn’t register. Really appreciate the help. Keep up the good work.
- November 22, 2019 at 11:00 am #93392
MemberYou are always welcome 🙂
- The topic ‘Enable all attributes by default’ is closed to new replies.
