Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Enquiry Module Upload file
- This topic has 5 replies, 2 voices, and was last updated 6 years, 7 months ago by
- January 11, 2019 at 9:58 am #43112
ben
ParticipantHi dear,
Need to add upload file on form “Enquiry Module”
exemple : customer can have possibility to joint file (pdf,doc, jpg, png) on request quote ‘Enquiry Module’thanks
- January 11, 2019 at 10:25 am #43118
Hope you know, it’s possible to create custom field for “Inquiry” from WCFM Admin Setting -> Inquiry Setting
But, upload field type is not there and it is due to security. Inquiry is open for all users, no login required. Now, people may upload malicious files to your site.
Best to handle this, create a “text” field and ask people to insert file link there. It will save your disk space as well 🙂
- January 12, 2019 at 12:06 pm #43208
ben
ParticipantDear, thank you for answer, and for consider security for me.
but I really need to add “upload file” to “inquiry” for allowed Extensions : jpeg,png,gif,pdf,pdf,doc. - January 12, 2019 at 1:35 pm #43215
ben
Participantthe best will be integrate : https://yithemes.com/themes/plugins/yith-woocommerce-request-a-quote/
To WCFM dashbord - January 13, 2019 at 4:30 am #43299
ben
ParticipantI have remove “//” from code and change to :
$field_types = apply_filters( ‘wcfm_product_custom_filed_types’, array( ‘text’ => ‘Text’, ‘number’ => ‘Number’, ‘textarea’ => ‘textarea’, ‘datepicker’ => ‘Date Picker’, ‘timepicker’ => ‘Time Picker’, ‘checkbox’ => ‘Check Box’, ‘select’ => ‘Select’, ‘upload’ => ‘File/Image’ ) );
on : wcfm-view-settings.php
Now on menu I have Upload file/image, but Upload sshow me only texte field when I add import file 🙁
whats wrong here ?
- January 13, 2019 at 7:33 am #43312
“Now on menu I have Upload file/image, but Upload sshow me only texte field when I add import file”
– Noting wrong, as I told you it’s not support file upload yet.We are checking this, will add file upload option.
- The topic ‘Enquiry Module Upload file’ is closed to new replies.
