Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Error on vendor connect stripe
- This topic has 10 replies, 3 voices, and was last updated 6 years, 10 months ago by
- October 6, 2018 at 10:15 pm #33463
nassim.tamoud
Participanthi,
vendors cant’connect stripe account, they have this error:
“error”: “invalid_redirect_uri”,
“error_description”: “Invalid redirect URI ‘https://www.amazigh.fr/tableau-de-bord/reglages/’. Ensure this uri exactly matches one of the uris specified in your application settings”,
“state”: “16”
}Can you help me ?
- October 7, 2018 at 4:24 am #33468
Which URL is this “https://www.amazigh.fr/tableau-de-bord/reglages/”?
Do you have set this URL at this URL at your Stripe account as return URL?
If not, then please set that.Redirect URL should be WCFM dashboard setting page URL for your site.
- October 7, 2018 at 12:44 pm #33496
nassim.tamoud
Participantthank you I have solved my problem, I actually did not put the correct redirection address on stripe. now its ok thanck you
I did a test with a seller account, i go very well on the registration page stripe but when I go back to my dashboard seller I have this message “please try again”
do you know this problem?
You must be logged in to view attached files. - October 7, 2018 at 3:09 pm #33498
Well, WCFM has two stripe setting – one for vendor payout and another for vendor membership.
As you are talking about registration that means you are talking about membership stripe setting right?
But that is not for vendor payment setting -> Stripe Connect!
- October 9, 2018 at 10:33 am #33585
Amazigh.fr
GuestHello,
I’m not talking about the membership registration but the stripe connection button in the vendor dashboard menu (see attached)It refers to a stripe registration form for the seller to create an account. But at the end of the procedure, we return to the dashboard with “try again” at the connection button stripe (see attachment)
do you understand?
- October 9, 2018 at 10:42 am #33586
nassim.tamoud
do you understand?
You must be logged in to view attached files. - October 9, 2018 at 10:44 am #33588
nassim.tamoud
Participantthis button on the vendor menu
You must be logged in to view attached files. - October 9, 2018 at 10:47 am #33590
nassim.tamoud
Participantafter sign in my vendor stripe account
You must be logged in to view attached files. - October 9, 2018 at 4:28 pm #33629
Something is wrong, in admin account or in vendor account!
Actually, there is no wrong in this connection, in fact today I have checked this 3 other sites and working perfectly.Is anything restricted from your stripe admin account?
Please check it’s configuration once!Thank You
- October 12, 2018 at 9:24 am #33858
nassim.tamoud
ParticipantThis reply has been marked as private. - October 13, 2018 at 7:03 am #33912
“stripe split pay” V/S “stripe”
Stripe split is for purchasing order and order completed as payment complete.
But Stripe is for paying out vendor commission, it can not be use for product purchase.
Then you have to use WC Stripe gateway for purchase – https://wordpress.org/plugins/woocommerce-gateway-stripe/Thank You
- The topic ‘Error on vendor connect stripe’ is closed to new replies.
