Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Event as only possible product type
- This topic has 1 reply, 2 voices, and was last updated 5 years, 3 months ago by
- May 11, 2020 at 5:02 pm #129579
Nico Bein
ParticipantHey guys!
I just bought WCFM Ultimate because I want to set up a marketplace for event tickets. I also have FooEvents.
What I would like to achieve is that a vendor can only add and sell tickets in the easiest way. No other products. Is that even possible with WCFM?
At the moment I don’t know where to start because all the options in WCMF are overwhelming (and maybe a bit confusing). Can you give me a hint where to start? Is there maybe some kind of tutorial for this?
Best,
Nico - May 11, 2020 at 6:03 pm #129604
I can understand your situation. WCFM offers a lot of functionality and not every business requires every function. The good news is you can disable all these extra modules from WCFM Dashboard (admin user) >> Settings >> Modules.
The next step is to reduce vendor options further by disabling all the capabilities that are not required. To do so, go to the Capability menu from your dashboard.
Now to remove all other post types apart from Event, open Capability page and under Types section disable all the post types that are not required. Once on this screen, I’ll also request you to review other options and disable any capability that is not applicable to your vendors.
Thank You!
