Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Exceeded maximum number of activations.
- This topic has 12 replies, 3 voices, and was last updated 8 years, 6 months ago by
- August 28, 2017 at 8:57 pm #12448
Fede
GuestI can not turn on the plugin and I get this error. How can I fix it?
I read that the license key for the “ultimate” version is just to receive updates and it should still work.
The problem is that after your update yesterday, it will not load the page for product modification. I only have a white page with, on the left, the menu without any css. (Minimal style).
See the pictures
https://www.dropbox.com/s/t4m597hri666zsj/Not%20load%20dashboard.png?dl=0
https://www.dropbox.com/s/omb47elwfyflz00/WCFM%20exceeded.png?dl=0 - August 29, 2017 at 4:12 am #12468
Kindly update WCFM FREE and Ultimate both at 3.0.0
It was a major update and both the plugin should be at latest version as those are very much dependent.Please go through this-
http://wclovers.com/faq/#1503979135377-ee50302a-6271If your license issue yet not fixed then please send us your Order No, we will reset that from our end.
Thanks for your patience …
- August 29, 2017 at 8:01 am #12477
Fede
ParticipantThis reply has been marked as private. - August 29, 2017 at 9:08 am #12478
We have just refresh WCFM Ultimate License key from our end, please try to activate it now.
But WCfM dashboard broken is no way part of WCFM Ultimate.
Can you please delete WCFM Free and reinstall it!!
Sometimes WordPress updates breaks between, may be same for your case.Thank You
- August 29, 2017 at 1:28 pm #12484
Fede
ParticipantSorry I tried to delate and reinstall the plugin but the problem there is still! Please let me know some fix. It’s urgent
- August 29, 2017 at 1:35 pm #12485
Yeah, I understood your urgency but I am also really confused with such absert issue.
Is it possible for you to give me an access to check your system?
- August 29, 2017 at 5:01 pm #12488
Fede
ParticipantOk, what kind of access you need? Admin or Vendor?
- August 29, 2017 at 5:20 pm #12489
MemberThanks for cooperation.
Hope you are getting the same issue as both the users!!
So both are preferable, otherwise only Admin will also be fine.
- August 29, 2017 at 7:00 pm #12491
MemberKindly send access at email, not here.
wclovers.contact@gmail.com - August 30, 2017 at 10:50 am #12528
WCfM Forum
Any updates?
Is that issue resolved for you !!Thank You
- August 30, 2017 at 2:24 pm #12529
WCfM Forum
I have checked the setup and found that you have issues only in Product Manager, other screens are working perfectly.
I also have have noticed your WC Bookings is at quite old version, can you please update it to the latest.
If I am trying to add a product then works fine but if I try to edit any existing product then breaks!!Please update WC Bookings and I am sure everything will again works as before.
Shhiv - August 30, 2017 at 7:56 pm #12530
Fede
ParticipantI did what you suggested and now everything works.
Thank you!!! - August 30, 2017 at 8:32 pm #12531
MemberAhh … That’s great.
Actually in WCfM 3.0 we have a added a feature which is available only in latest WC Booking update.
- The topic ‘Exceeded maximum number of activations.’ is closed to new replies.
