Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › exclude custom fields in selected "product type" not working probably.
- This topic has 1 reply, 2 voices, and was last updated 7 years, 11 months ago by
- May 10, 2018 at 4:36 am #23089
Day
GuestHi support,
After i upgraded to the latest version, i found that there is a new function to control if the block of custom field should be excluded in the selected “product types”, but seems this function is not working probably.
When i try to mark exclude the block from “Simple product” product type, it just disappeared in all the types, not only “Simple product”. I don’t know if this issue is happening only on my site or not, as i have followed your instruction in another post (https://wclovers.com/forums/topic/new-product-type/) to add an extra product type “GroupBuy”.
- May 10, 2018 at 8:42 am #23109
First know me, are you able to add Custom Product type in WCfM dashboard?
“After i upgraded to the latest version, i found that there is a new function to control if the block of custom field should be excluded in the selected “product types”, but seems this function is not working probably.”
– It works perfectly but may be not working for your case due to something else.
Can you please show me your custom field setup screenshot?It will be also very helpful if you allow to check the things as a vendor login!
Shhiv
- The topic ‘exclude custom fields in selected "product type" not working probably.’ is closed to new replies.
