Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Export product to CSV file feature does not work
- This topic has 8 replies, 4 voices, and was last updated 6 years, 1 month ago by
- April 14, 2019 at 11:25 pm #57755
delbertgordon
ParticipantI am attempting to export my products to csv file but nothing happens when i click on “generate csv”
- April 15, 2019 at 7:06 am #57832
Well, if you have disable “wp-admin” access from WC Vendors setting panel, then remove that restriction setting.
Still you may apply this restriction on vendor from WCFM Capability setting.
- April 22, 2019 at 1:42 pm #58930
Oliviersl
GuestHi, neither export nor import work, even after allowing wp-admin access. Please check.
- April 24, 2019 at 9:09 am #59142
Which multi-vendor plugin you are using “WC Vendors”?
Please go to WCFM Capability setting and click “save” button once.
Are you using any other user role editor plugin or membership plugin which may restrict vendors from accessing wp-admin area?
For vendor users disable wp-admin only form WCFM Capability setting.
- June 25, 2019 at 8:56 am #69484
Kumar Rajesh
ParticipantWhen product csv file exporting, the product Description is coming in html format.
- June 26, 2019 at 5:04 pm #69840
You have saved description in HTML so it’s obvious you will receive that raw data.
- June 27, 2019 at 6:04 am #69959
Kumar Rajesh
ParticipantThank you for reply, their is one issue while exporting, I m not getting product brand in csv, and how to import brand with product using csv or any other way to do. Need help.
- June 27, 2019 at 2:20 pm #70015
Kumar Rajesh
ParticipantStore setup url is showing wp-admin.php, is their way to change that url.?
- June 29, 2019 at 4:25 pm #70250
MemberWe will change this in coming update!
- The topic ‘Export product to CSV file feature does not work’ is closed to new replies.
