Diwali
02Day 02Hr 40Min 33Sec
Diwali
Extends custom product type from woocommerce
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Extends custom product type from woocommerce
Viewing 4 reply threads
    • #81139
      jaliascv
      Hi. is there any way the woocommerce custom product types are automatically loaded into wcfm ?
      thanks!
    • #81152
      jaliascv
      hi i managed to add custom product type. but need to modify many files as the list array are mostly hardcoded. thanks!
    • #81713
      No, you don not require to edit any core file.
      You may add new product type using this code snippet –
      add_filter( 'wcfm_product_types', function( $pro_types ) {
      	$pro_types['new_product'] = __( 'New Product', 'woocommerce' );
      	return $pro_types;
      }, 50 );
    • #89376
      rockprince7
    • #91003
      Well, that code is only for adding new product type under WCFM Product manager.
      But before doing that you have to register a new product type for WooCommerce.
      You may check this for the purpose – https://webkul.com/blog/create-a-custom-product-type-in-woocommerce/
      Thank YOu
  • The topic ‘Extends custom product type from woocommerce’ is closed to new replies.
