Fatal Error in WooCommerce Multivendor Marketplace
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Feature Request Fatal Error in WooCommerce Multivendor Marketplace
Viewing 12 reply threads
    • #44046
      d.bastian75
      Help me please!
      My favorite website is https://www.jbonline.co.id/ every day and every time I take care, almost all my days are spent on caring for him.
      This morning I woke up and I opened the website suddenly it looks messy.
      I searched where the error was, and I found in error-log there was only one place
      [17-Jan-2019 04:00:34 UTC] PHP Warning: get_class() expects parameter 1 to be object, string given in/ / /wp-content/plugins/wc-multivendor-marketplace/helpers/wcfmmp-core-functions.php on line 657
      I can’t delete this plugin, because I have set it up in such a way, and I have already paid for the supporting plugins that must be paid.
      And I also didn’t find a plugin that is better than this.
      I really can’t solve this problem, please help me …
    • #44048
      I am really sorry for the trouble.
      Kindly, disable line no. 665 for now.
      We will take care of this in next update.
    • #44054
      d.bastian75
      Do you mean I deleted one line in line 665?
    • #44056
      Yeah, delete that for now.
    • #44057
      d.bastian75
      My website is now back to normal after I disable the wc-multivendor-marketplace plugin.
      I then re-enable the plugin because I do not want to lose users.
      Temporarily it still looks normal, but on the error-log page the error is still increasing.
      Thus what I said.
      Thanks for the support
    • #44058
      Don’t disable plugin, just delete that line for now.
      That line is for WooCommerce POS, and you are not using that, so nothing will happen if you delete that.
      We will take care why it’s throwing error.
      Possibly you are using JetPack, right?
    • #44059
      d.bastian75
      Is it not compatible with jetpack?
      Should I turn off jetpack?
    • #44064
      It off course compatible with JetPack, but recently one of JetPack API service causing some issues. And this happen to many sites.
      Here is same, that API response not properly parsed.
      Don’t deactivate any plugin, just disable that line for now.
    • #44065
      d.bastian75
      OK. Thank you so much for your help.
      I have made your advice, and it looks like it’s better now. loading is also not slow.
      I am waiting for the next update
      thank you
    • #44066
      Great … you are welcome 🙂
      I will know you as new update will be there.
    • #45240
      WCFM 5.3.1 has already released and we have taken care of this.
    • #46651
      Adhiraj
      I need help I activate woocommerce multivendor plugin n my story is crashed , I can’t enable to open my control panel it’s showing fatal error, without my control panel access how can I deactivated this plugin
    • #46655
      Please delete that plugin folder from cPanel or FTP of your site.
      Also check PHP error log from cPanel, why it’s throwing 500 error.
      Be sure, your site’s PHP version should be above 5.6
  • The topic ‘Fatal Error in WooCommerce Multivendor Marketplace’ is closed to new replies.
