Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Feature Size Detail
- This topic has 3 replies, 3 voices, and was last updated 5 years, 2 months ago by
Viewing 3 reply threads
- January 20, 2020 at 8:00 am #102795
- February 7, 2020 at 12:59 pm #106073
MemberThis support added in WCFM latest version, 6.4.1
- February 23, 2020 at 7:32 pm #108389
Adam
ParticipantHi!
I am using WCFM free version (latest) on a test instance and installed Advanced Size Chart plugin but faced problem in excluding size chart from any category/product while adding product through wcfm. If add product directly through woocommerce there is option to select size chart but while using wcfm, one of the size chart automatically get selected and dont have option to not select any size chart. I didn’t set any size chart with any default category. SS attached herewith.
ThanksAttachments:
You must be logged in to view attached files. - February 25, 2020 at 1:25 pm #108691
MemberThanks for mentioning this, we will take care of this in WCFM next update.
