Featured, top stores widgets not showing up
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Featured, top stores widgets not showing up
Viewing 1 reply thread
    • #100209
      aliuk28
      I can’t get the featured products or top stores etc widgets to work on any of the themes. what am I doing wrong?
    • #102447
      You’ve to add “Vendor Store: Featured Products” and “Marketplace: Top Rated Vendors” widgets for this and meanwhile can you please specify which theme you are using.
      Using these widgets should work but if it doesn’t then please do share us your website login details.
      Please do share your website details as private reply only.
