Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Filtering by attributes
- This topic has 19 replies, 3 voices, and was last updated 6 years, 5 months ago by
vraugul1.
- March 15, 2019 at 6:21 am #52775
vraugul1
ParticipantHello!
Not found information on this issue on forum.
How to turn on the wcfm_stores page and on the pages of the stores vendors
filtering by attributes?Thank you!
- March 15, 2019 at 6:27 am #52780
WooCommerce has a filter widget for this – https://ibb.co/1ZpBmpY
Add this to Store Sidebar.
- March 15, 2019 at 6:36 am #52783
vraugul1
ParticipantHello!
And how to do it in Store List Sidebar?
I added, but the filter does not appear in the Store list Sidebar.Thank you!
- March 16, 2019 at 9:02 am #52938
Well, this filter is only for Product Archive pages, so will work in Store Page, but not at Store List page!
- March 16, 2019 at 12:26 pm #52990
Alex
GuestThe only solution is “woocommerce product filter” plugin…
It is absurd that a “multivendor” plugin does not have filters like that.
- March 17, 2019 at 6:22 am #53059
– You may use this plugin for WCFM Marketplace store page as well!
- March 18, 2019 at 5:36 am #53181
vraugul1
ParticipantHello!
This one?
https://yithemes.com/themes/plugins/yith-woocommerce-ajax-product-filter/?refer_id=1038801Thank you!
- March 18, 2019 at 10:10 am #53252
Well, as I know this works for store pages as well.
- March 18, 2019 at 10:51 am #53259
vraugul1
ParticipantHello!
Can you give this plugin?
- March 19, 2019 at 5:44 am #53414
vraugul1
Participant?
- March 19, 2019 at 6:29 am #53418
MemberHere it is – https://drive.google.com/file/d/1h3hf4wFMTox50Frweeo43nq67QJV9Y2E/view?usp=sharing
- March 19, 2019 at 6:38 am #53419
vraugul1
ParticipantThis does not work on the Stores page (wcfm_stores)
- March 19, 2019 at 7:05 am #53423
Alex
GuestHey vraugul1!
The plugin is not the one they told you!
This one:
- March 19, 2019 at 8:13 am #53456
vraugul1
ParticipantThis plugin also does not work
- March 19, 2019 at 8:14 am #53457
vraugul1
ParticipantHello!
Tell me how to filter the stores according to the attributes?
On the page wcfm_storesThank you!
- March 19, 2019 at 5:17 pm #53562
MemberSorry, there is no such filter available.
- March 20, 2019 at 11:42 am #53680
vraugul1
ParticipantHello!
Can you make it?
- March 29, 2019 at 5:12 am #55129
vraugul1
Participant???
- March 29, 2019 at 7:51 am #55143
MemberWe have no plan yet to create this!
- March 29, 2019 at 8:59 am #55147
vraugul1
ParticipantHello!
Very bad, the multivendor plugin should be filtering stores by attributes of goods.
- The topic ‘Filtering by attributes’ is closed to new replies.
