01Day 11Hr 16Min 27Sec
Fix WCfM Menu Manager
Viewing 6 reply threads
    • #26508
      d-n-13
      Hello wcfm team,
      The new WCfM Menu Manager needs default URL to be fixed, otherwise it won’t work in WPML multilingual (check attached screenshot)
      of course the temporary fix it to do it manually, disable then enable each menu to see the URL and fix it.
    • #26524
      d-n-13
      Also Vendors now can see all admin Menus… of course it shows permission notice ” Capability: You don’t have permission to access this page. Please contact your Store Admin for assistance.”
      But they shouldn’t be able to see it.
    • #26525
      d-n-13
      “of course the temporary fix it to do it manually, disable then enable each menu to see the URL and fix it.”
      This won’t fix it.
    • #26531
      d-n-13
      I will be waiting for a fix or option to disable the new menu feature
    • #26576
      WCfM 4.2.2 version just updated. It fixes these issue.
      Kindly update and take a look.
      Actually, in 4.2.0 update vendor menu controller was missed, so we had updated 4.2.1 on very soon after 4.2.0 to fix this.
      But wordpress.org didn’t triggered that update, may be their server issue.
      Sorry for the inconvenience.
    • #26590
      d-n-13
      This has been fixed, Thanks!
    • #26591
      Thanks for confirming me this 🙂
  • The topic ‘Fix WCfM Menu Manager’ is closed to new replies.
