Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › free trial days limitation
- This topic has 3 replies, 2 voices, and was last updated 6 years, 8 months ago by
Ramamurthy Krishnan.
- February 1, 2020 at 9:30 am #104900
aemr45
I would like to know if its possible not allow vendors to add products during trial period, just save products as draft.
- February 4, 2020 at 3:30 am #105281
Ramamurthy Krishnan
Yes you have use our “WOOCOMMERCE FRONTEND MANAGER – GROUP & STAFF” addon plugin for this feature. After installing this plugin you need to create a group and disable the “Add Products” capability and then assign this group to the specific membership plan with trial period. When users register under this plan they will not be able to add products but giving the users product adding capability after trial period will be a manual process. I mean after trial of each vendor you have to manually remove that vendor from the group to again give them product adding capability.
WOOCOMMERCE FRONTEND MANAGER – GROUP & STAFF: https://wclovers.com/product/woocommerce-frontend-manager-groups-staffs/
- February 4, 2020 at 9:41 am #105309
aemr45
ParticipantHi Molay Das,
Thank you for your answer , although is not practical. Just keep it in mind for future updates please.
Regards.
- February 5, 2020 at 11:42 am #105505
Ramamurthy Krishnan
KeymasterHi @aemr45,
Thanks for the suggestion.
We’ll definitely try to add this feature in our future updates.Thanks,
- The topic ‘free trial days limitation’ is closed to new replies.
