Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Front End Product Editor
- This topic has 3 replies, 2 voices, and was last updated 6 years ago by
- August 9, 2019 at 5:10 pm #75991
shackbill
ParticipantThis is a very cool feature but i have a request. My Single Product page is standard WooCommerce so the editor works fine but i use a custom Grid Builder (wpgridbuilder.com) for the main shop page so i guess the front end editor is no supported there. Would it be possible to add support for this?
You must be logged in to view attached files. - August 12, 2019 at 9:39 am #76228
What support you want to add over there?
Product quick manage options?
- August 12, 2019 at 9:43 am #76230
shackbill
Participantyes.. if the quick manage options can be added to the main shopping grid (just like the single view), that would be great. Another useful feature in the main grid would be the ability to use the mouse to grab and move the item to a different location (manual sorting). Not sure if that is something that’s possible, but it would be useful. thanks.
- August 13, 2019 at 5:21 am #76348
Well, we will look to add “Quick Manage” options here.
But for sorting options you have to reach that plugin support as this grid is from their plugin!
