Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WC Vendors › Frontend dashboard fields
- This topic has 4 replies, 2 voices, and was last updated 6 years, 9 months ago by WCFM Forum.
- March 27, 2018 at 3:36 pm #20962elricka.lamyParticipant
Thanks for your plugin.
Everything work well, I just have trouble when I want to manage product for exemple (and every fields on the wcfm dashboard) (see picture).
All the fields and labels are inverted.
I tried to manage by customise css (in child theme) but it doesn’t look well.The plugin work with WC Vendor and a directory theme.
So could you help me please ?
Best regards,
ElrickaAttachments:
You must be logged in to view attached files. - March 27, 2018 at 7:49 pm #20966WCFM ForumMember
hi,
Don’t worry, these all can be fixed very easily. And definitely these are CSS fixes.
Is this possible for you to share a demo access of you with us to fix the things?
- March 27, 2018 at 9:41 pm #20969elricka.lamyParticipantThis reply has been marked as private.
- March 28, 2018 at 9:27 pm #21039WCFM ForumMember
thanks for the credentials, I am just looking into this.
Language will not an issue 🙂
Thanks again for your cooperation.
- March 28, 2018 at 9:36 pm #21040WCFM ForumMember
Can you please add this CSS to your site and know me is everything looks perfect or not?
#wcfm-main-contentainer input[type="text"], #wcfm-main-contentainer select, #wcfm-main-contentainer input[type="number"], #wcfm-main-contentainer input[type="time"], #wcfm-main-contentainer input[type="search"], #wcfm-main-contentainer textarea { float: none; }
- The topic ‘Frontend dashboard fields’ is closed to new replies.
