Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Frontend RnB System Settings
- This topic has 4 replies, 4 voices, and was last updated 7 years, 9 months ago by
- November 14, 2017 at 4:37 am #15722
alexychang93
I am using RnB WooCommerce Rental & Bookings System and WC Marketplace. When I go to add a new product on the front end, it shows the settings tab. How do I remove this or limit what’s shown on here? Thanks!
You must be logged in to view attached files. - November 14, 2017 at 4:53 am #15726
Sorry, I am afraid to say that there is no such control panel for that.
I think ” RnB WooCommerce Rental & Bookings System” also has no such things.Still, if you want to hide something from your vendors then send us those list, we will do that for you.
Simha - November 15, 2017 at 3:52 pm #15796
alexchang93
GuestWould it be possible to remove all this information and force the vendors to use global settings? I have attached the image for reference. THis is under: wcfm/wcfm-products-manage/ Thanks!
Image: https://ibb.co/hE5nNm
- November 16, 2017 at 5:09 am #15810
Shhiv Narayan
Thanks for the idea.
Let me check how this can be achievable!!Thank You
- December 6, 2017 at 9:50 pm #16598
We have hide all those settings options by default and only Global option selected.
Now if user change option to Local then only setting options will be visible.Hope this will resolve your issue as well.
- The topic ‘Frontend RnB System Settings’ is closed to new replies.
