Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Frontend Vendor Product Image not able to upload
- This topic has 8 replies, 2 voices, and was last updated 6 years, 6 months ago by
- September 21, 2019 at 3:53 pm #82791
lawrence_jacque
Tried to upload an image from WC Frontend Dashboard using a vendor account (Wcfm_Vendor) and it shows “Sorry, you are not allowed to attach files to this post.”
Tried the following approaches:
1. Upload the image via the enabled wp-admin (back-end): Able to upload image successfully
2. Reset all the capabilities under Woocommerce -> Tools: UNABLE to upload image successfully
3. Check if there is a plugin known as WP User Avatar but not installed.
Can you please advise what else I can do to fix this bug ?
Thank you.
You must be logged in to view attached files. - September 22, 2019 at 10:00 am #82878
lawrence_jacque
Any updates?
- September 22, 2019 at 2:54 pm #82935
Please go to WCFM Capability and press “save” once.
Between, do you have any other user role controller plugin?
Are you using WCFM Affiliate plugin?
- September 22, 2019 at 4:55 pm #82958
lawrence_jacque
Please go to WCFM Capability and press “save” once. -> Hi are you referring to the screenshot? I have tried and the problem persists.
Between, do you have any other user role controller plugin? -> Disabled all user role controller plugin
Are you using WCFM Affiliate plugin? -> No.
You must be logged in to view attached files. - September 22, 2019 at 7:58 pm #82978
lawrence_jacque
have checked both the Roles setting in WordPress (Users -> Roles) and WCFM Capabilities section but I was not able to find which exact setting has to be enabled to allow wcfm_vendor to upload image as I am not that well familiar with the plugin inner workings.
Hope you can help answer this as this issue only arises when front end is activated.
- September 23, 2019 at 8:22 am #83069
lawrence_jacque
Did a few tests with WCFM Frontend Manager and below are the findings:
1. Assigned Administrator to the vendor user account and able to upload image
2. Assigned Shop Manager to the vendor user account and able to upload image
3. Assigned Store Vendor to the vendor user account and not able to upload image
Seem the Store Vendor is not able to upload. In addition, this vendor is activated using
WCFM – WooCommerce Multivendor Membership.Kindly advise.
Thank you.
- September 24, 2019 at 9:37 am #83318
– Which plugin you had? Do you remember, if you changed anything for “Store Vendor” user role?
Well, user role is WP property, if you changed this using any plugin and then delete that but still changes are save in WP, you can not alter that by deactivate or delete plugin.
Have to edit that user role again and restore to it’s initial state.
Please share your site access with us, we have to check “Store Vendor” user role permissions – https://wclovers.com/woocommerce-multivendor-customization/
- September 27, 2019 at 10:30 am #83952
lawrence_jacque
ParticipantNoted with thanks.
Will try again before engaging you.Thank you.
- September 30, 2019 at 10:56 am #84445
MemberOK, feel free to know us.
- The topic ‘Frontend Vendor Product Image not able to upload’ is closed to new replies.
