Durga Puja
02Day 17Hr 28Min 06Sec
Durga Puja
Full Width Layout
Viewing 8 reply threads
    • #90058
      johmabe
      Why is the WCFM Layout broken on my website?
      using it with Buddyboss Marketplace…
      Tried changing fonts… Tried changing page to full width, nothing worked. Many check boxes don’t work around the site and it just looks weird. Any help?
    • #90864
      The attachments you attached are not opening. Can you please share them once again so that we can check whats really the issue?
    • #90886
      johmabe
      not sure what happened, here goes
    • #91144
      I’ve been through the screenshots. We can’t figure out whats happening around there unless you provide us the site details.
      Feel free to share your site credentials along with forum topic thread link with us here – https://wclovers.com/woocommerce-multivendor-customization/
    • #91247
      johmabe
      I would gladly share details but at the moment I can’t as I am transitioning servers. I might get the full version of WCFM soon.
      I just needed to force full width on the WCFM as it won’t adapt to neither the theme (BuddyBoss Marketplace) nor page full width commands…I assume full width is the only way to properly visualize everything in WCFM as I tried small fonts and they didn’t work.
    • #91267
      It will be great if you share your website details after your server transition and we will gladly help you for this. Unless we have the access we can’t figure out whats the issue is.
      • #95450
        johmabe
        • #95465
          Don’t worry just share us your site access and we will definitely help you if there’s an issue.
          • #95684
            johmabe
            • #96388
              I’ve changed the wcfm dashboard view to full width.
              Please check it once and do let me know if any other issues.
              • #96906
                johmabe
    • #97206
      The checkbox issue has been fixed also. Yes, I’ve added css code under wp-admin->Buddyboss->OneSocial Theme->Custom Codes section.
    • #103279
      johmabe
    • #103410
      Glad to hear that it worked because it was nothing to do with my code as I had worked on css files only.
      But one thing I noticed that your site is getting “504 gateway time-out nginx” error, so you can contact your hosting provider for this.
  • The topic ‘Full Width Layout’ is closed to new replies.
