Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › GEOLOCATION based Marketplace
- This topic has 21 replies, 10 voices, and was last updated 6 years, 4 months ago by
Prachait.
- August 24, 2019 at 8:13 pm #78206
labdhee mehta
Participanthttps://wedevs.com/dokan/modules/geolocation/
With this extension, admin will be able to:
Set the location of the map in where it will be shown in the page
Enable filtering option for customers to search for their location
Enable the location tab in the single product page
Set a maximum/minimum distance which the users can set when searching
With this extension, customers will be able to:
Search for a product in a specific area
Set the radius distance when searching
Search using differenct metrcis. Such as Kilometre/Miles
Set a maximum/minimum distance which the users can set when searchingI am looking to create a marketplace which will allow the customer to search products in their vicinity for hyper fast deliveries.
Using the geomywp plugin, i am able to search stores which belong in that region but a user cannot search it by product.
So say if someone searches for apple iphone, they will find it but they will not know which store or whether they will be able to deliver HYPER FAST (this is the USP of the idea)
Looking for a way to allow the customer to predetermine the product location and also the vendor to set their radius of coverage for delivery with in 24 hours (hyper fast), currently we can do it using pin codes, but again there is no way to display the shipping description to the customer.
Anyway, the way currently wcfm is built up, it will not allow product search according to location, which IMHO sucks.
Dokan has this but doesnt have delivery + other features of wcfm.
wcfm has all other features of dokan but i wonder how they forgot this.Any customer searches using product name, not vendor store name, geolocation displays stores and then user has to check out products inside the vendor store, one way will be to ask user to first search for vendors in their region and then using widget of the store product search would allow to further search for products in that store.
it would be so much nicer if the customer can search for product name, geolocation already detected and entered in the location tab and then display results and show distance from the current location to the store/product.
Geomywp offers nearby locations extension but i am not sure if we can integrate it on the vendor level.
Looking for a solution to this, and i am sure when we have a solution for this we will also have a solution to allow users to search for products without the location filter as a mandatory field, this is for rural area orders, where 24 hour delivery is not possible but loss on revenue / customer is also unacceptable.
Please help guys! Hope a few more customers of WCFM would like to do this as well, please reply if you do guys.
- August 28, 2019 at 10:36 am #78728
labdhee mehta
ParticipantBUMP!
- March 12, 2020 at 4:23 am #111268
ashlee.e.mcfarland
ParticipantThis is exactly what I am looking for as well, please make this possible!
- April 1, 2020 at 10:34 pm #114551
hugo.lopes
ParticipantMe too!
- April 4, 2020 at 12:50 pm #115255
MemberWell, WCFM Marketplace already has this module and even in Free version.
You just have to setup WCFM Admin Setting -> GEO Location – https://ibb.co/YBBwXxF
Hence you will have radius filter for store list page – https://wcfmmp.wcfmdemos.com/stores/
and product archive pages – https://wcfmmp.wcfmdemos.com/Thank You
- April 4, 2020 at 3:07 pm #115313
hugo.lopes
ParticipantI was testing it, thanks a lot!
Just one question, is it possible to enter the adresse from the profil of the user and block it?
I would love to define a maximum ratio to 10 KM?Thanks a lot this product is amazing!
- April 5, 2020 at 10:53 am #115551
– Sorry, not get this. Do you want to disable “address” edit once it filled up by vendors?I would love to define a maximum ratio to 10 KM?
= Please add this snippet to your site –add_filter( 'wcfm_max_radius_to_search_options', function( $max_radius ) { $max_radius = array( '10' => '10', '15' => '15', '20' => '20', '50' => '50', '100' => '100', '150' => '150', '200' => '200', '500' => '500' ); return $max_radius; });Add this code to your child theme’s functions.php
- April 6, 2020 at 11:00 pm #116035
hugo.lopes
ParticipantThank you!
For the center of the radius, the user is now entering (or is geolocated) the address.
Is it possible to take it from his profil?
(he has enter a location for delivery)THanks a lot,
Hugo
- April 12, 2020 at 12:26 pm #118323
Well, vendors are adding only one address at their setting -> Location – https://ibb.co/nk0kB6W
What you want to change for this?
- April 13, 2020 at 3:23 pm #118693
hugo.lopes
ParticipantMy problem is that wih my phone I’m located in an other city, So I belive that the clients of the website will have the same problem.
It’s why I would like to have the clients located directly with the address that they enter in the form “postcode”.
For the sellers it’s perfect like that.
Hope it’s more clear?
HugoAttachments:
You must be logged in to view attached files. - April 15, 2020 at 5:30 pm #119363
abbassariya2
ParticipantI also urgently require this. The customer location is automatically detected or the customer is prompted to add their address.
Then with a set radius, the particular vendors products are shown which can be delivered to them. The products will be shown if they are in the particular radius.Kindly please reply.
Regards.if we can use google place api to get location of customer and give them result of shop which is nearby to them and we can set specific range from the shop where we deliver product .
why we need this feature in multi vendor marketplace??
1) we receive many orders but it is outside the delivery area customer make payment through payment gateway then we cancel order (payment stuck for minimum 74 hours) because of shop can not make delivery at their place customer get disappointed for that and they rely on us and we can not complete their wish .*can is it possible we get location of user and then display them shops nearby them using google place upi -> we already store longitude and latitude of shop ->then we set specific km radius to shop where they can deliver the order.
it can helpful for us to make vendor and customer connect using google place api
if there is plugin like this please let me know sir if wcfm can able to add this feature its much more helpful for me
please reply ASAP - April 20, 2020 at 8:28 pm #121049
labdhee mehta
ParticipantDistance rate shipping intergration has been pending for almost a year now.
That should make so many users happy.
Pluginhive offers good shipping plugins for WCFM but doesn’t have distance wise.
This is the time of UBER/SWIGGY.
Lets do this. - April 22, 2020 at 1:24 am #121523
japerez
ParticipantHi guys, I don’t know if we are looking for the same thing, but, we are trying to set the site to show only vendors and products which are in a defined area.
In other words, if a customer enters the vendors page, no matter where he is, and no matter if there are vendors in other places, it should only show him the vendors that are in the area that I set.
Is this possible in any way, tweaking the code or anything?
Thanks a lot in advance.
Kind regards. - April 22, 2020 at 12:42 pm #121668
hugo.lopes
ParticipantHi Japerez, You can already do that 🙂
I just want to have a Geo location more efficient and set with the city of the user.
Cheers, - May 2, 2020 at 4:12 pm #125695
nasier.nas
ParticipantHi. i want to disable ‘delivery lcoation’ on checkout field for customer. I already uncheck the setting on geo location. But the field still there. Already clear cache but still same. Please help. Please refer to my screenshots attachment.
You must be logged in to view attached files.- May 5, 2020 at 12:39 pm #126852
Sarmistha Chakraborty
We have already replied you in this https://wclovers.com/forums/topic/how-to-disable-delivery-location-field-on-checkout/ thread.
- June 21, 2020 at 4:03 pm #142962
pk20210845
ParticipantHi, I want to create a grocery store with a multi-vendor and I want that user can only order in his location. Means – All products will be location-specific. Users can view products as per Pincode.
If the seller is from location A then he can only sell his product in his location and if the customer is from location B then he can’t order that product. (but the product should be visible for all)
Is it possible with this? Please reply fast thanks 🙂
- June 24, 2020 at 1:02 pm #143798
hugo.lopes
we are currently developing that, maybe we can share ressources to have the best outcome?
Cheers
- June 24, 2020 at 1:14 pm #143801
pk20210845
ParticipantHow much time it would take to launch this feature?
- June 25, 2020 at 12:17 am #143936
hugo.lopes
ParticipantLess than a month
- June 25, 2020 at 9:44 am #144024
pk20210845
Participantthanks
- July 22, 2020 at 12:43 am #153688
Prachait
ParticipantHi, We are still waiting for this pincode selection feature !
- The topic ‘GEOLOCATION based Marketplace’ is closed to new replies.
