Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Ghost vendors in membership plans
- This topic has 9 replies, 3 voices, and was last updated 6 years, 7 months ago by
- January 14, 2019 at 5:18 pm #43520
Jose
ParticipantAt the beginning of the installation I created 3 vendors, which then, and may be the reason, I deleted 2 of them from WordPress users.
Now that I want to use only one plan, I can’t erase the other, since there are ghost vendors.
I have searched the database and can’t find a way to delete them.I hope you can help me.
Regards,Attachments:
You must be logged in to view attached files. - January 15, 2019 at 2:46 am #43551
alastair
ParticipantI am also having this problem!
I can’t delete a membership:
https://www.dropbox.com/s/ga02pvlxl6ctibk/Motored%20-%20can%27t%20delete%20membership.png?dl=0But I have no vendors:
https://www.dropbox.com/s/y2rvm8x05ifkwg9/Motored%20-%20no%20vendors.png?dl=0 - January 15, 2019 at 10:55 am #43666
Jose
ParticipantThanks Alastair,
You confirm that is a bug.
Regards,
- January 16, 2019 at 8:44 am #43843
We have test this and it works fine – https://www.useloom.com/share/59362b9048f048d09c296362cae28234
Are you guys deleting users some other way?
- January 16, 2019 at 10:41 am #43875
Jose
Thanks for showing your test.
I don’t know why, but I have 2 ghost vendors, and I can’t delete it.
How I said, I erase from wordpress users.But now, I have problems, because I need only one membership plan.
Will be better if you can advice me how to delete.
Regards,
- January 17, 2019 at 2:54 pm #44097
Jose
ParticipantResolved !
From Phpmyadmin I erase all user except me, and in table posts erase where I found relative to plans.
Now need to test.
What happend if I don’t like plans, just define a fixed commission ? Can the vendor step register skip plan step ?
Regards,
- January 17, 2019 at 4:10 pm #44120
Just check, wp-admin -> Pages -> there is a direct registration page “Vendor Registration” as well -> you may use this to register without membership
- January 17, 2019 at 4:17 pm #44121
Jose
ParticipantOk thanks !!
I have a page with shortcode [wcfm_vendor_registration]
But if I go, just show the shortcode.
Need to have membership plugin active without a plan ?
Regards,
- January 17, 2019 at 4:22 pm #44125
Jose
ParticipantResolved !!
Active membership without plan, work perfect.
Thanks so much !!
- January 17, 2019 at 4:40 pm #44132
- The topic ‘Ghost vendors in membership plans’ is closed to new replies.
