Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Go not Multivendor Marketplace
- This topic has 6 replies, 2 voices, and was last updated 5 years, 4 months ago by
- April 26, 2020 at 9:39 am #123147
Marina-Martens
I had already installed it and everything went perfectly
What have you done now no longer works and everything has changed
I register myself as a seller first what is a farmer why not in German where I put it
Now, as a seller, I can no longer post any productsI haven’t finished it all or why it doesn’t work anymore
It worked so well and everything was perfect. Easy operation now it has become very complicated and
you no longer climb throughHave you Screenshots
also get no notification of entries
I will not see this displayed
Sreenshot
as shown in the screenshot other option is not available
You must be logged in to view attached files. - April 26, 2020 at 11:01 am #123155
KeymasterHello,
Thank you for contacting the support and sorry for any inconvenience that might have been caused due to that.
From the attached scrrenshot and the description you provided, I couldn’t be able to understand the issue. What options are you referring as missing? Please check if all WCFM plugins, that you are using, are activated.
You provided us the screenshot of Settings >> “Product Custom Field” page. Every option/field in that image is correct. Only the “Fields” panel is collapsed and can be expanded by clicking on the arrow symbol next to it. Please refer to this image- https://imgur.com/wOdcxw5
I’m not sure if that answers your question or not. If not, please provide us more details along with some more snapshots of the problems.
Looking forward to helping you.
- April 26, 2020 at 2:03 pm #123205
Marina-Martens
ParticipantFollowed her instructions but I still can’t change from not showing to showing although I added a new field
Maybe I did not click the right tab with text, I have to click another field, I have now clicked text
the add products option is not displayed on this page
thanksCan you take a look at my page where the mistake is and write to me I have several pages and need the info yet I add them as a user
You must be logged in to view attached files. - April 26, 2020 at 2:21 pm #123212
Marina-Martens
Participantand how to delete an account
and I don’t get an e-mail when I register, how do I do that, all the notifications have been stopped
thanks
- April 27, 2020 at 8:23 pm #123770
KeymasterHello,
Have you updated form an earlier version of WCFM Marketplace? Are you facing these issues after plugin update?how to delete an account
WCFM doesn’t provide user deletion from frontend dashboard. Please do that from wp-admin >> Users.
Go to settings >> Notification manager and check if all the notifications are enabled or not. Ref: https://imgur.com/N526DD4
If all the notifications are enabled and still you aren’t getting any email the please install https://wordpress.org/plugins/wp-mail-logging/ plugin. And, check if the emails are getting triggered or not.
- April 26, 2020 at 4:42 pm #123261
Marina-Martens
ParticipantNow I have found the REiter inserting products in the bottom right corner
how can you make the tab Butten above left or right with letteringHow do I manage it with variations as a buyable product? I am shown this product is currently sold out
- April 27, 2020 at 8:34 pm #123775
KeymasterHello,
Sorry, I’m still not getting your queries. So which ever part I understand, I’m trying to provide an answer.I am shown this product is currently sold out
Edit the product which is showing “sold out” and go to Inventory tab from there. If “Manage Stock?” option is enabled then you’ll require to put a positive value under Stock quantity field. Ref: https://imgur.com/sD5AOiH
To know how can you set a variable product please follow this tutorial – https://www.youtube.com/watch?v=6aALTKvqHkk
