Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Good Job!
- This topic has 4 replies, 2 voices, and was last updated 7 years, 2 months ago by
- October 10, 2018 at 9:27 am #33692
javier
ParticipantThanks … I must say that its complement is great, it works perfectly.
But I have some situations that I would like to solve:
1.- At the end of the purchase, I would like the mail and the phone number of the store (seller) to appear in the summary of the purchase, since currently only the name appears.2.-I wish it were possible to add that the seller adds the cost of their shipments but considering the weight of their products.
3.-solve visualization problems in the names of the products when they are observed in the store version (attached image)
my website tucarritomarket.com
Congratulations!!!
You must be logged in to view attached files. - October 10, 2018 at 9:27 am #33694
- October 11, 2018 at 11:18 am #33792
– This option is already there. Vendor Customer Support option is there for the purpose. Hence support address, email and phone will go to customer’s email and also visible at order details page along with store policies (https://ibb.co/jULA19).
All info will be in Store Invoice as well.2.-I wish it were possible to add that the seller adds the cost of their shipments but considering the weight of their products.
– How you want to consider this? Shipping Classes are already there for the purpose.
– Can you pleas share a store url from your site to check this?
- October 16, 2018 at 9:42 pm #34147
javier
ParticipantHi friends
Thanks for the answers.
The explained a little the problem of the shipments:
In Mexico, shipments are based on weight, for example sending a product costs the following:1kg product = 10 usd
product of 2 kg = 12.5 usd
product of 3 kg = 15 usd
product of 4 kg = 17 usd
.The idea is that each seller can add the costs according to the weight of their product, in such a way that when adding the products of the same seller to the cart the total weight is added and with it the value of the shipment can be calculated
thanks
- October 17, 2018 at 2:47 pm #34198
You can achieve this very easily using WC Shipping class.
If you need help in setting this please know me.
- The topic ‘Good Job!’ is closed to new replies.
