Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Google map issue
- This topic has 5 replies, 2 voices, and was last updated 6 years, 3 months ago by
Izaque Bastos.
- May 7, 2019 at 9:24 pm #61088
sdel_nevo
ParticipantHi guys
I have set up my google map api and configured this with billing.
The google map shows correctly on the store list page and is not in development mode, but is always shown over Egypt when loaded not the UK.No vendors are shown on the map at all
If a vendor entered there location on the google map location in there store manager settings an error is shown “this page can’t show maps correctly “
No matter what I do I cant get google maps to show the vendors location
If a customer try’s to enter there location in the radius search on the store list page they get the same error
This happens with or without GEO Locate enabled in settings
Please advise
Steve
- May 8, 2019 at 8:04 pm #61196
sdel_nevo
ParticipantHi guy
Found this link in the https://wclovers.com/forums/topic/store-location/ and used your API to test
When I used your api the address worked (although the map still started in Egypt)
As soon as I put my API Back it failed again
My api has no restrictions either on the api or web address so now I’m even more confused than ever
I have sent you some e-mails with screen shots as I have been getting tons of errors on your forums when trying to add attachments
Steve
- May 8, 2019 at 8:27 pm #61208
sdel_nevo
Well it’s very odd, I have managed to sort it
I put your API back in, and entered an address into a vendors location
Then put my api back and low and behold it worked!!
No idea why
When the map shows it’s very zoomed in almost to street level
Is it possible to set the zoom of the map to further away
Steve
- May 8, 2019 at 8:35 pm #61213
sdel_nevo
It appears that the location search is still broken with my API, getting this page can show maps error when typing in the location search box
As said my API has no restrictions at all and has billing setup
My site works with your api but not mine
It is definitely the Java api that’s required is it
Steve
- May 9, 2019 at 10:23 am #61345
sdel_nevo
ParticipantHi Guys
I have been trying to get my google map API to work without any lunch at all
the map shows properly and is not in developers mode and is linked to a billing account,
attached is a screenshot of my API settings, no restrictions are in place
however
as soon as a location is entered into the store list search, or a vendor tries to enter their location in the Find location area, the error “this page can’t show maps correctly “ appears
when I test with the API from the linked forum post it works really well
am I missing something really sill now? or do I have to enable another API?
Steve
You must be logged in to view attached files. - June 5, 2019 at 5:11 pm #66021
Izaque Bastos
ParticipantI have the same problem. As soon as a location is entered in the search of the list of stores or a provider tries to enter its location in the Find location area, the error “This page can not show maps correctly” appears.
- The topic ‘Google map issue’ is closed to new replies.
