Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Groups and staff incompatibility
- This topic has 5 replies, 2 voices, and was last updated 6 years, 4 months ago by
kaloomee.
- August 9, 2019 at 8:21 pm #76004
kaloomee
I have groups and staff plugin installed
When manager/vendor adds/manages new staff the vendor/manager is given the option of ‘Capabilities’ Which is great feature but…..
As site admin I have some settings:- example ‘Product types’ disabled globally sitewideSurely that this setting should be preset in this staff/manager capabilites to reflect the same
ie – any capabilities that I have set, as admin, as disabled, should be set to disabled in staff/manager capabilities tooOtherwise vendors/managers will be able to override the site admins settings, this would also get confusing for managers as they might set one of the globally disabled options as enabled but it would not, Or should not, work
Even better – Any options set globally by site admin should not be displayed (Hidden) in vendor/manager capabilities area
Regards
Kaloomee - August 9, 2019 at 8:33 pm #76006
kaloomee
ParticipantAha – figured out that this does work for most fields but not for ‘Integrations’
I have Fancy product designer installed and setting this option to ‘off’ does not hide it in the capabilitiesAny update or help much appreciated
Kaloomee - August 12, 2019 at 9:56 am #76235
– Where you have set this OFF ?
- August 12, 2019 at 11:55 am #76254
kaloomee
ParticipantI have this set to ‘Off’ in :-
Admin > Capability > capability settings – Integrations – Fancy Product Designer = Off
And
Groups > (Select the group) > Capabilities – Integrations – Fancy Product Designer = Off
This is set to off for the only 2 groups that I haveBut when vendor managers staff – capabilities – Vendor still sees – Integrations > Fancy product designer as option – on or off
As previously mentioned I have set to ‘off’ some of the other options ie – product types etc, these are hidden, so pretty sure that I understand how to hide fields/options, It is just the integrations > Fancy Product Designer that are not hidden.Also – Integrations are hidden in products management – I did initially have a problem with this (fancy product designer was displaying so you provided code to fix – https://wclovers.com/forums/topic/hide-product-fancy-menu-tab/
No reply yet though to your reply ‘Please wait till WCFM Ultimate next update, we will add “Capability” option for this. Just set that OFF and all fancy Designer element will disable for vendors.’
has this been added?Thank you
- August 13, 2019 at 5:37 am #76352
OK. we will take care of this in next update.
- August 13, 2019 at 9:16 am #76404
kaloomee
ParticipantMost excellent, Thank you
Great support as ever
- The topic ‘Groups and staff incompatibility’ is closed to new replies.
