Hide a specific attributein WCFM
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Hide a specific attributein WCFM
Viewing 7 reply threads
    • #77243
      Eddy Trivulce
      Hi
      How can i hide a specific attribute in the frontend manager for vendor ?
      Thank you in advance for the reply
      Eddy
    • #77300
      neonsidee
      If I’m correct, check capabilities tab in WCFM
    • #77304
      Eddy Trivulce
      Hi
      Thank for your reply but no i want to hide only one attribute or just do that vendor can’t add
      a new value on this attribute but not for all the attributes which is the option in the capabilities.
      I want to hide it because it causes a flaw in my theme.
      Kind regards
      Eddy
    • #77478
      You can do all these from capability setting – https://ibb.co/vqjjK9x
      Select other attributes here except that – https://ibb.co/gR8MGfN
    • #77523
      Eddy Trivulce
      Hi
      Ok thank you, i need WCFM Ultimate for these options ?
      I bought it but my licence is out to date but when i bought it there wasn’t no notion of time :p
      No matter, you are doing a good job so if I renew my license I have some questions.
      For WC Job Manager, is it this version that is integrated ? https://wpjobmanager.com/add-ons/wc-paid-listings/
      For WC Action, is it this version that is integrated ? https://codecanyon.net/item/woocommerce-simple-auctions-wordpress-auctions/6811382
      Optional : I’m using the Wyzi business finder theme that works with wc marketplace but I would love to use the WCFM Marketplace because there are many more options and flexibility for vendors. The theme uses Paid Membership Pro for seller memberships and different options and I can not bypass that. I think there is a minimum of custom development to make it compatible and I have discussed it with the Wyzi developers as well but I’m waiting for the answer. Can you tell me or look at whether custom development is complicated to do? I think a lot of Wyzi users might be interested in this but it’s still to be verified.
      Kind Regards
      Eddy
    • #77796
      – What will vendor do with this?
      – Yeah, it’s compatible.
      – Are you sure, it’s essential to use this membership plugin? Please confirm this from Theme support.
      WCFM Marketplace has own membership module – https://wordpress.org/plugins/wc-multivendor-membership/
    • #77862
      Eddy Trivulce
      For Wc Job manager, i was thinking of that because my theme is a business directory so you can have all possible jobs.
      I don’t know this plugin exactly but i think you can do a marketplace like fiverr with that so a business owner can purpose a web site development or a plugin or translation, videos or others jobs for money. The possibilities are infinite. This plugin allows it, isn’t it or maybe I’m wrong ?
      This is not a priority at the moment but my site is compatible with WC job manager free.
      Ok good for WC Simple Auction, I will probably buy this plugin.
      And yes, i’m sure that paid membership pro is essential for my theme but i’m interested by the pay per product option but i don’t know how integrated it for the moment. I will think about the question.
      The developers of the theme told me that they would look to make WCFM Marketplace compatible or at least look at it more closely. I hope they will do it.
      Kind Regards
      Eddy
    • #77970
      – Great … thanks for the update.
  • The topic ‘Hide a specific attributein WCFM’ is closed to new replies.
