Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Hide Commission Invoice Totals
- This topic has 4 replies, 2 voices, and was last updated 6 years, 9 months ago by
- June 27, 2019 at 8:42 pm #70059
shitT
ParticipantHello
On the commission invoice, the only relevant total for my vendors is “total fees”. The other totals are only confusing.
How can I hide the other totals? (Taxes, Shipping, Shipping Tax and Gross Total -> see also attachment) I guess it has something to do with the “wcfm_order_totals_after_total” action, but I need a hint to get further.
Your help would be greatly appreciated!
You must be logged in to view attached files. - June 29, 2019 at 4:58 pm #70263
Well, vendors are getting same view at their order details.
Are you OK with that?
wcfm_order_totals_after_total – if we change anything with this hook then it will reflect all the areas for vendors.
- June 29, 2019 at 5:06 pm #70266
shitT
Thanks for you answer.
I think I understand the problem. So the best would be not to use the hook and create a custom “total” section. Right?
- July 1, 2019 at 11:51 am #70503
shitT
ParticipantI solved this by creating my custom “total” section and it works. Topic closed.
- July 1, 2019 at 3:19 pm #70583
MemberGreat … thanks for the update!
- The topic ‘Hide Commission Invoice Totals’ is closed to new replies.
