01Day 14Hr 23Min 57Sec
hide "Enable reviews" option at Advanced tab for Vendors only?
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate hide "Enable reviews" option at Advanced tab for Vendors only?
Viewing 5 reply threads
    • #82039
      Makers
      Hello WC Lovers!
      Is there any way to hide the “Enable reviews” option at Advanced tab for Vendors only? (Image attached) So that Admins would still have the option to enable reviews when they add their own products, but vendors will not be able to.
      I’ve turned off the Store Reviews module and reviews in the menu manager, but the option is still there. I’m not sure if I’m missing this option somewhere though?
      Thank you for your assistance!
    • #82453
      Store Reviews is not related to this.
      Please add this code to your site for the purpose –
      add_filter( 'wcfm_product_manage_fields_advanced', function( $advance_fields, $product_id ) {
      	$advance_fields = wcfm_hide_field( 'enable_reviews', $advance_fields );
      	return $advance_fields;
      }, 50, 2 );
    • #82539
      Makers
      Thank you for this it seems to work great for this purpose.
      The only other thing I’d also like to be able to do would be… By default have enable reviews unchecked when they add a new product. Since they currently don’t see the option because we added the code above and it’s enabled/checked by default. I understand if this isn’t something you can assist me with.
      I appreciate your help very much!
    • #82825
      Well, this use this revised code –
      	if( !$product_id && isset( $advance_fields['enable_reviews'] ) ) {
      		$advance_fields['enable_reviews']['dfvalue'] = '';
      }, 50, 2 );
    • #82837
      Makers
      Works perfect!
      Thank you very much!
    • #82944
      Great 🙂
  • The topic ‘hide "Enable reviews" option at Advanced tab for Vendors only?’ is closed to new replies.
