Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Hide Gross Sales Column From Vendors
- This topic has 8 replies, 4 voices, and was last updated 6 years ago by
- May 14, 2019 at 9:15 pm #62239
mshafiqtahir.macit
I didn’t like to show Gross Sales to our vendors. I have seen this solution https://wclovers.com/forums/topic/show-net-sales-only/ but this does not work for me because this can remove from reports only.
- May 15, 2019 at 3:45 pm #62308
Maru
GuestHi, I am creating a rental marketplace and I would like to eliminate Gross Sales from the vendor dashboard. I have seen this solution https://wclovers.com/forums/topic/show-net-sales-only/ but this does not work for me because this can remove from reports only.
- May 16, 2019 at 1:51 pm #62481
Member - September 7, 2019 at 10:51 pm #80653
pongaloenhvblog
ParticipantHi! Video is down, how can I hide gross Sales from vendor dashboard and order details?
- September 9, 2019 at 11:32 am #80794
Member - September 9, 2019 at 6:22 pm #80877
pongaloenhvblog
ParticipantThanks!!
But still appearing gross price in order detail. Is there any way to hide only to vendors? Thanks! - September 14, 2019 at 9:56 pm #81620
add_filter( 'wcfm_is_allow_gross_total', function( $is_allow ) { if( function_exists( 'wcfm_is_vendor' ) && wcfm_is_vendor() ) $is_allow = false; return $is_allow; });
- September 15, 2019 at 3:57 pm #81801
pongaloenhvblog
ParticipantThanks but doesn’t worked for me using code snippets.
Here is an screenshot.
You must be logged in to view attached files. - September 17, 2019 at 7:30 pm #82152
Well, you asked me to hide “Gross Total”.
These are not Gross Total! Certainly there is no filter to hide this. You may try using CSS.
- The topic ‘Hide Gross Sales Column From Vendors’ is closed to new replies.
