Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Hide options in the product shipping section
- This topic has 9 replies, 3 voices, and was last updated 8 years, 1 month ago by
Shhiv Narayan.
- November 14, 2017 at 6:21 am #15732
- November 14, 2017 at 6:38 am #15735
Shhiv Narayan
These are coming from WC Vendor Pro and it has some setting for this, can you please try with them.
- November 14, 2017 at 6:48 am #15737
javier
Participanthello, thanks for the reply, I already completely deactivate the shipping settings in wc vendors pro, but the options indicated in the image do not disappear.
- November 14, 2017 at 8:43 am #15740
javier
ParticipantI have deactivated all the wc vendors pro shipping options and they disappear correctly, even active wcfm and everything works fine, but when I activate the addon ultimate, the shipping rates section appears.
Apparently it is a feature of wcfm ultimateHelp me please please
- November 14, 2017 at 8:45 am #15741
javier
ParticipantThis reply has been marked as private. - November 14, 2017 at 10:26 am #15744
WCfM Forum
You have already mailed us your staging access.
Let me check and know you.
Frankly, wC Vendors Pro has too many checkboxes and I also can’t track which is for what!!Don’t worry I will remove those options from there.
- November 14, 2017 at 4:41 pm #15747
javier
ParticipantThis reply has been marked as private. - November 15, 2017 at 10:37 am #15785
Shhiv Narayan
Did you checked my mail yet?
I have already send tou the solution for this!
- November 15, 2017 at 8:32 pm #15799
javier
ParticipantI have disabled the option, even if you create the product from the wp-admin the options of “shipping ratings” disappears, also with the wcfm basic works well, the real problem is when we activate the wcfm ultimate because those shipping rates appear
I do not know what the problem is
Thanks for the help
- November 16, 2017 at 4:59 am #15807
Shhiv Narayan
We have already fixed that as well.
Kindly check now.
- The topic ‘Hide options in the product shipping section’ is closed to new replies.
