Hide (or preferably, display on same line) the Store: Example Store in mini cart
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Hide (or preferably, display on same line) the Store: Example Store in mini cart
Viewing 4 reply threads
    • #67145
      Alex Ostbringhaus
      I have been trying to get a mini cart working for my site for hours now, but all mini cart modules/shortcode/plugins seem to be confused by the additional details wcfm adds. How I can have the store that the item was purchased from display on the same line in a simple table format? if this is not possible, then how can I hide these extra details?
    • #67425
      Well, as I see this mini cart is broken, even product image and title also no visible properly!
      Between, which theme you are using ?
    • #67600
      Alex Ostbringhaus
      I am using astra theme, with beaver themer to create the headers. I have disabled the product image, and widened the window for now, to simplify the example (please see the image attached). How can I display the store on the same line as the item?
    • #67853
      Well, it’s visible at next line by WooCommerce core.
      Store is here as product meta, same like variable product.
    • #120357
      olivier-6093
      How to remove “store:” in mini cart?
      • #120375
        To remove “Store” meta,
        You have to override the “cart-item-data.php” file in your theme (yourtheme/woocommerce/cart/cart-item-data.php). Then add this below code in this file,(PFA)
        if($data['key'] == 'Store') {
          continue;
        But in this case “store” will remove from cart and checkout.
  • The topic ‘Hide (or preferably, display on same line) the Store: Example Store in mini cart’ is closed to new replies.
