Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Hide product Fancy menu tab
- This topic has 4 replies, 2 voices, and was last updated 6 years, 10 months ago by
- May 24, 2019 at 11:16 am #63579
kaloomee
I have WCFM and Fancy product designer
But fancy menu tab is visible to Vendors
I have unchecked the
Settings > Menu manager > Product Designer
But vendor still sees the fancy product tab – https://nimb.ws/93j0paCan you please let me know what other settings I need to change to hide this menu tab from vendors – Visible to admin only
KaloomeeAttachments:
You must be logged in to view attached files. - May 26, 2019 at 6:56 pm #63884
OK, we will add “Capability” setting for this in next update.
You may add this to child theme’s functions.php to disable this for vendors –
add_filter( 'wcfm_is_allow_fancy_product_designer' , function( $is_allow ) { if( wcfm_is_vendor() ) $is_allow = false; return $is_allow; }, 200 );Thank You
- May 27, 2019 at 7:48 pm #64011
kaloomee
ParticipantThank you
Works just as requestedThank you for the great support
- May 28, 2019 at 9:50 am #64084
kaloomee
I have just noticed that the same applies to the ‘Orders’ section – Fancy product designer fields are visible
Between ‘Shipment tracking’ and ‘Order items’ tabs – See attachment
Would you mind supplying code to hide this as well please?
Thanks in advance
kaloomeeAttachments:
You must be logged in to view attached files. - May 29, 2019 at 7:31 am #64229
Please wait till WCFM Ultimate next update, we will add “Capability” option for this. Just set that OFF and all fancy Designer element will disable for vendors.
- The topic ‘Hide product Fancy menu tab’ is closed to new replies.
