hide vendor product label collapse tabs
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Vendors hide vendor product label collapse tabs
Viewing 1 reply thread
    • #107227
      ozkancol
      i add plugin woocommerce advanced product labels
      i’m using it from admin page
      but store vendor page is visible ..i want to hide
      attached picture
    • #107433
      add_filter('wcfm_is_allow_wc_advanced_product_labels','check_wcfm_is_allow_wc_advanced_product_labels');
      function check_wcfm_is_allow_wc_advanced_product_labels($bool) {
      	$userid = get_current_user_id();
      	if(wcfm_is_vendor($userid)) {
      		$bool = false;
      	return $bool;
