Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Hide wcfm_dashboard_wcfm_product_stats on dashoboard
- This topic has 4 replies, 3 voices, and was last updated 5 years, 9 months ago by
SebastianFloKa.
- May 20, 2020 at 10:35 pm #133605
lab4brains
ParticipantIs there a filter to be able to hide this component (.wcfm_dashboard_wcfm_product_stats) from the dashboard?
- May 26, 2020 at 2:14 pm #135342
Sarmistha Chakraborty
add_filter('wcfm_is_allow_dashboard_product_stats', '__return_false');
Try this code to your child theme’s functions.php
In case you do not have child theme then add code using this plugin – https://wordpress.org/plugins/code-snippets/Thanks.
- May 27, 2020 at 3:57 pm #135722
SebastianFloKa
ParticipantHi @Sarmistha Chakraborty
As I have a similar question: hope it’s fine to post here:
Is there a possibility to hide the “product policy” field in the product manager and keep the “storewise” policy tab in the vendor store settings section? So that the policy enterned in the setting section should be visible to customers as currently. But vendor should not be able to modify the policy per product (for legal reason) so therefore if the complete policy tab would not show up in product-manager would be great.
Thank you.
- May 27, 2020 at 9:45 pm #135937
To remove “Product Policies” tab from the product manager, add this code in your theme’s functions.php –
add_action('wcfm_init','remove_translate_option_for_vendor',100); function remove_translate_option_for_vendor() { if( wcfm_is_vendor() ) { global $WCFM, $WCFMu; remove_action( 'after_wcfm_products_manage_tabs_content', array( $WCFM->wcfm_policy, 'wcfm_policy_product_settings' ), 100, 4 ); } }Thanks.
- May 28, 2020 at 1:11 am #135973
SebastianFloKa
ParticipantThat was fast and works perfect. Thank you very much!!
