Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Hiding Fields/Options in "Add Product" page
- This topic has 6 replies, 3 voices, and was last updated 8 years ago by
Bingal.
- March 9, 2018 at 3:42 pm #20023
Jay
I would like to hide some fields for vendors when they add/edit product.
Specifically, Menu Order from Advanced tab and Up-sell option from Linked tab.Can you provide code snippet to do this?
- March 9, 2018 at 3:50 pm #20029
Bingal
Please first go through WCFM Capability, you may disable many of them from there.
Still if you have anything left, then please know me, will definitely give you code snippet for the purpose.
- March 9, 2018 at 5:55 pm #20042
Jin
GuestI’ve went through the capability setting, I cannot disable individual field I listed.
For example, I can disable whole “Linked” tab but I cannot disable “upsell” option within “Linked” tab.
- March 9, 2018 at 6:55 pm #20047
Don’t worry, I will give you code for those.
Here is one for hiding “Menu Order” from Advanced tab –
function wcfm_product_manage_fields_advanced_manipulate( $advanced_fields, $product_id ) { if( wcfm_is_vendor() && isset( $advanced_fields['menu_order'] ) ) { $advanced_fields['menu_order']['class'] = 'wcfm_custom_hide'; $advanced_fields['menu_order']['label_class'] = 'wcfm_custom_hide'; } return $advanced_fields; } add_filter( 'wcfm_product_manage_fields_advanced', 'wcfm_product_manage_fields_advanced_manipulate', 50, 2 );Thank You
- March 9, 2018 at 7:13 pm #20049
Here is the code for hiding “Up sells” option –
function product_manage_fields_linked_manipulate( $linked_fields, $product_id, $products_array ) { if( wcfm_is_vendor() && isset( $linked_fields['upsell_ids'] ) ) { unset( $linked_fields['upsell_ids'] ); } return $linked_fields; } add_filter( 'product_manage_fields_linked', 'product_manage_fields_linked_manipulate', 50, 3 );Thank You
- March 9, 2018 at 7:25 pm #20051
Jin
GuestThank you so much for your help!
It is now working as I wanted.
- March 10, 2018 at 6:24 am #20068
Bingal
KeymasterGreat … welcome 🙂
- The topic ‘Hiding Fields/Options in "Add Product" page’ is closed to new replies.
