Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › How can i create an order manually
- This topic has 1 reply, 2 voices, and was last updated 5 years, 5 months ago by
Sayan Naskar.
- February 9, 2020 at 10:36 pm #106326
xavier.bonello
I have been using your plugin for a long time and I have a problem. For several reasons, I cannot use WCFM API requests. So I try to create an aorder manually except that it does not insert a line in my wp_wcmp_vendor_orders database.
So I try to create in my functions.php the SQL query but is there a way to do it with an endpoint or other.Can you help me ?
Thx and sorry for my English - February 13, 2020 at 3:38 pm #106987
Sayan Naskar
As you mentioned the table name to be wp_wcmp_vendor_orders so, I guess you are using WCMP marketplace plugin not our WCFM marketplace plugin. So as you see the Rest API Requests are complete up to WCMP and the data insertion in the database is also managed by their plugin. Moreover from WCMP version 3.4 we have stopped further development support for WCMP..Thank You.
