Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › How can i HIDE unnecessary FIELDS in product-publishing page and PRESET values?
- This topic has 8 replies, 2 voices, and was last updated 6 years, 10 months ago by
- October 23, 2018 at 7:04 am #34619
Lwifunyo Mangula
ParticipantHello! Hi!
Thanks for the good work and great customer support you are providing. its great.I want to soon use Woocommerce Booking and accomodations to offer booking service from my vendors.
But
I have found the product publishing form has many fields and too technical for very normal user to set and publish his/her booking product!I want to
– preset some fields to all vendors so that they can go without worrying and miss-setting
– I want to hide some fields and some selections (hide some checkbox and dropdown values in selections boxes). I have tried CSS but i have seen css hide many fields which others i want to be seen. Maybe how can i overide with theme template and hide and rename other fieldsThanks very much ij advance
- October 24, 2018 at 4:26 pm #34775
Just relax, but don’t use CSS for the purpose.
All these are possible using PHP code.Please know me your requirement, I will help you accordingly for the purpose.
- October 25, 2018 at 7:40 am #34920
Lwifunyo Mangula
ParticipantSIR THANKS FOR YOUR TIME. THESE ARE MY REQUESTS.
FIELDS TO BE PRE-SETS
==general product settings
– has persons
– has resources
– virtual product==booking options
– booking duration==>customer defined
– time unity==>days
– minimum duration==>1 day
– maximum duration==>30 days
– enable calendar range picker==>yes
– Calendar display mode==>always visible==persons tab
– enable person types
– min persons==>20
– max persons ==>50
– multiply all costs by person count==yes
– count persons as bookings==yes
– person type 1 name CONSULTANT. ==base-cost 5000. ==block cost 5000. ==min 20. ==max 50. ==description xxxxxxxxxxxxx.
– person type 2 name DRIVER. ==base-cost 3000. ==block cost 3000. ==min 20. ==max 40. ==description yyyyyyyyyyyy.==availability tab
– maximum booking per block==>100
– minimum block bookable ==>1 day
– maximum block bookable ==> 30 days
– First block starts at…==> 0100 hours
– availability rule==> range days. ==from monday. ==to sunday. ==bookable YES. ==priority 10.==resource tab
– Resource label name==>ADDITIONAL SERVICES
– resource are==>customer selected==cost tab
– base costs==5000
– block costs==3000
display costs==5000
– cost rule type==range of days. ==from monday-sunday. ==base-cost (x) 3000. ==block cost (x) 5000.FIELDS TO HIDE IN VENDOR BOOKING PUBLISHING FORM
== general product settings
– catalog
– downloadable==booking option tab
-requires confirmation
-can be cancelled== availability tab
-require a buffer period of
-adjacent buffering
-restrict start days
-restricted days
– hide block additional plus button (vendor can not add more block)1. your html function code at first for me to solve the problem.
2. Since this plugin is THE NEXT THING IN WOOCOMMERCE and many people are in need of these functionality in our plugin, then I personally I advice to add an intensive module which maybe can be a table form which will
– list all plugin fields, text, words, sentenses, placeholders, default values
– enable admin to hide and unhide some of fields and values to vendor
– enable admin to pre-set default value
– enable admin to pre-set fields and vendor can not change them
– set minmum and maximum field values. set interval value
– enable admin to make them required or optional fields
– enable admin to change text, descriptions, sentences to his own words - October 25, 2018 at 10:00 am #34938
Thanks for all the details.
Are you comfortable in WP hook/filter coding?
If yes, then here is sample plugin for such purpose – https://drive.google.com/file/d/16a1OuGUHmbZLW9Io9fyaHE8-LpOcifNo/view?usp=sharing
Please install this and check.
then you have to modify this a bit as per your requirement.Thank You
- October 27, 2018 at 4:52 pm #35142
Lwifunyo Mangula
ParticipantHello again sir!
thanks for the sample plugin you have provided for me!
– it has been so helpful. i have done a lot well with it!
Thank you!There are few things i need help from you!
1. in person block there are ready predefines input blocks! I want also to add pre-defined input blocks with data, but i have failed. below are codes
=======> the person types you have provided isfunction wcfmbi_wcbokings_person_types_fields( $person_fields, $product_id ) {
global $WCFM, $WCFMbi;if( !$product_id ) {
if( isset( $person_fields[‘_wc_booking_min_persons_group’] ) ) {
$person_fields[‘_wc_booking_min_persons_group’][‘value’] = 1;
}if( isset( $person_fields[‘_wc_booking_max_persons_group’] ) ) {
$person_fields[‘_wc_booking_max_persons_group’][‘value’] = 1;
}if( isset( $person_fields[‘_wc_booking_person_cost_multiplier’] ) ) {
$person_fields[‘_wc_booking_person_cost_multiplier’][‘class’] = ‘wcfm_custom_hide’;
$person_fields[‘_wc_booking_person_cost_multiplier’][‘label_class’] = ‘wcfm_custom_hide’;
$person_fields[‘_wc_booking_person_cost_multiplier’][‘dfvalue’] = ‘no’;
}if( isset( $person_fields[‘_wc_booking_person_qty_multiplier’] ) ) {
$person_fields[‘_wc_booking_person_qty_multiplier’][‘class’] = ‘wcfm_custom_hide’;
$person_fields[‘_wc_booking_person_qty_multiplier’][‘label_class’] = ‘wcfm_custom_hide’;
$person_fields[‘_wc_booking_person_qty_multiplier’][‘dfvalue’] = ‘yes’;
}if( isset( $person_fields[‘_wc_booking_has_person_types’] ) ) {
$person_fields[‘_wc_booking_has_person_types’][‘class’] = ‘wcfm_custom_hide’;
$person_fields[‘_wc_booking_has_person_types’][‘label_class’] = ‘wcfm_custom_hide’;
$person_fields[‘_wc_booking_has_person_types’][‘dfvalue’] = ‘yes’;
}if( !$product_id ) {
if( isset( $person_fields[‘_wc_booking_person_types’] ) ) {
$default_person_types = array( 0 => array(‘person_id’ => 0,
‘person_name’ => ‘Normal Ads Posts’,
‘person_description’ => ”,
‘person_cost’ => ”,
‘person_block_cost’ => 2500,
‘person_min’ => 0,
‘person_max’ => ‘100’
1 => array(‘person_id’ => 0,
‘person_name’ => ‘Top Cover Photo’,
‘person_cost’ => ”,
‘person_block_cost’ => 50000,
‘person_min’ => ‘0’,
‘person_max’ => ‘1’
2 => array(‘person_id’ => 0,
‘person_name’ => ‘Pin Ad at the Top’,
‘person_cost’ => ”,
‘person_block_cost’ => 30000,
‘person_max’ => ‘2’
3 => array(‘person_id’ => 0,
‘person_name’ => ‘Admin Promo and Mention’,
‘person_cost’ => ”,
‘person_block_cost’ => 25000,
‘person_max’ => ‘5’
$person_fields[‘_wc_booking_person_types’][‘value’] = $default_person_types;
$person_fields[‘_wc_booking_person_types’][‘options’][‘person_cost’][‘class’] = ‘wcfm_custom_hide’;
$person_fields[‘_wc_booking_person_types’][‘options’][‘person_cost’][‘label_class’] = ‘wcfm_custom_hide’;
$person_fields[‘_wc_booking_person_types’][‘options’][‘person_block_cost’][‘label’] = ‘Cost’;
}return $person_fields;
}———————————this is person type codes from sample plugin and it is working well——————————
From it i have derived my codes for RESOURCES, but unfortunately no blocks are added
function wcfmbi_wcbokings_resource_fields( $resource_fields, $product_id ) {
if( isset( $resource_fields[‘_wc_booking_resources’] ) ) {
$default_resources = array( 0 => array(‘resource_id’ => 0,
‘resource_title’ => ‘i love my wife’,
‘resource_base_cost’ => ‘11111’,
‘resource_block_cost’ => ‘22222’,
1 => array(‘resource_id’ => 0,
‘resource_title’ => ‘i love my children’,
‘resource_base_cost’ => ‘33333’,
‘resource_block_cost’ => ‘44444’,
2 => array(‘resource_id’ => 0,
‘resource_title’ => ‘i love my family’,
‘resource_base_cost’ => ‘55555’,
‘resource_block_cost’ => ‘66666’,
3 => array(‘resource_id’ => 0,
‘resource_title’ => ‘i love my people’,
‘resource_base_cost’ => ‘77777’,
‘resource_block_cost’ => ‘88888’,
$resource_fields[‘_wc_booking_resources’][‘value’] = $default_resources;
$resource_fields[‘_wc_booking_resources’][‘options’][‘resource_base_cost’][‘class’] = ‘wcfm_custom_hide’;
$resource_fields[‘_wc_booking_resources’][‘options’][‘resource_base_cost’][‘label_class’] = ‘wcfm_custom_hide’;
$resource_fields[‘_wc_booking_resources’][‘options’][‘resource_block_cost’][‘label’] = ‘Cost’;
}return $resource_fields;
}———————————- i need some modifications sir from you —————————————
2. How can i remove ADD and REMOVE buttons (right bottom buttons) in person and resource form so that vendors can not add or remove any block i have provided by the codes above; i want them only to fill them.
thanks in advance for my two questions.
- October 29, 2018 at 12:44 pm #35241
Just relax, I will write this code for you.
Well, we normally do such work as paid customization.
But I am not asking anything to you, it will be good if you donate us anything.Between, I will give you this code by tomorrow.
Thank Yoou
- October 29, 2018 at 2:59 pm #35259
Lwifunyo Mangula
Participantokey. thanks.
few weeks to come
i will do something to you sir.thanks in advance
- October 31, 2018 at 4:55 am #35365
It’s OK.
I will send your code in few hours.
- November 2, 2018 at 3:40 pm #35600
Sorry for a bit delay.
Here is your custom plugin – https://drive.google.com/file/d/1GtKUEo2PhADerxlqbH8Z7DLufLmy0lXE/view?usp=sharing
Use this and delete previous one.
- The topic ‘How can i HIDE unnecessary FIELDS in product-publishing page and PRESET values?’ is closed to new replies.
