Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › How can i save Product after Edit
- This topic has 16 replies, 4 voices, and was last updated 6 years, 11 months ago by
- September 2, 2018 at 3:41 am #30452
shyakat.com
ParticipantHi, when i edit a Product.. i can’t find the submit button !
How can i or my vendors save after edit - September 2, 2018 at 6:04 am #30465
Don’t you have “Submit” and “Draft” button at product manager page?
Do you have button at other pages?
Can you please enable “Disable Float Button” option from WCFM Admin Setting -> Dashboard
- September 2, 2018 at 9:54 pm #30554
shyakat.com
GuestYes the button is showing in other page.
“Disable Float Button” is enabled.
When i disable “Frontend Manager – Ultimate” the button works.. i think there’s a compatibility problem
- September 2, 2018 at 11:11 pm #30556
Ed
ParticipantSame problem here (image 1). Maybe problem is related to templates or plugins. If I resize the window, a part of the button is shown (Image 2).
Here it does not work with:
Porto
Beaver
Divi
Twenty Seventeen
StorefrontBut works with Thrive Nouveau (image 3)
By the way, I bought WCFM Ultimate thinking that only in this version would I be able to save the changes … But (still) I’m not sorry because Ultimate version seems to have everything I need.
You must be logged in to view attached files. - September 3, 2018 at 6:01 am #30601
What is your WCFM and WCFM Ultimate version?
If possible please give me a demo vendor access to check this.
- September 3, 2018 at 6:06 am #30603
shyakat.com
ParticipantThis reply has been marked as private. - September 3, 2018 at 9:04 am #30629
Ed
ParticipantThis reply has been marked as private. - September 3, 2018 at 9:20 am #30630
Thanks for the details.
I have just checked and found that “Disable Float Button” is not yet enabled.
Your theme does not support Float Buttons, so please disable this option.
- September 3, 2018 at 10:30 am #30648
shyakat.com
ParticipantI just disabled “Disable Float Button” still not working
- September 3, 2018 at 10:53 am #30649
Are you saving after enable the checkbox?
As I still see buttons are floating – https://ibb.co/fEmHueIf it’s disabled then buttons will be steady like this – https://ibb.co/fYRNSz
Do you have TeamViewer?
- September 3, 2018 at 11:09 am #30650
shyakat.com
ParticipantThis reply has been marked as private. - September 3, 2018 at 12:13 pm #30652
Should I connect you now?
- September 3, 2018 at 12:17 pm #30654
shyakat.com
ParticipantThis reply has been marked as private. - September 3, 2018 at 12:22 pm #30656
It’s not allowing me to connect you- https://ibb.co/c1hScz
You may connect me – 852 249 424
4464Thank You
- September 3, 2018 at 12:39 pm #30663
Sorry, I am having some issue on that machine.
Please connect me here – 964 233 894
1996Thank You
- September 3, 2018 at 12:41 pm #30664
shyakat.com
ParticipantThis reply has been marked as private. - September 3, 2018 at 12:44 pm #30665
It’s still not allow me to connect.
You just connect me here – 964 233 894
1996
- The topic ‘How can i save Product after Edit’ is closed to new replies.
