Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › How could add slider post instead of original banner at store vendor page?
- This topic has 6 replies, 2 voices, and was last updated 6 years, 10 months ago by
MOHO.
- August 24, 2018 at 7:02 am #29463
MOHO
ParticipantThe banner of vendor page is upload image at seetting.
But i wnat to change this area for slider with many image and link to vendor post
If the vendor post with image.
The banner of vendor change catch from this vendor the feature of post?
Feature image set as vendor page banner
so if the vendor add three posts, then the banner of vendor will carousel each post image
when the customer click the image, then go this single post page.
But the banner of store list keep the original store banner of setting.
I just want to change the banner of vendor page for post slider.
Could make it?
You must be logged in to view attached files. - August 24, 2018 at 7:32 am #29475
Very soon we will going to add support of slider and video banner.
But not from vendor’s posts, they have to add images/video from store setting panel.
- August 24, 2018 at 8:56 am #29489
MOHO
ParticipantGreat!!! I can’t waitting for.
- September 2, 2018 at 8:23 am #30482
MemberThis has been added in WCFM Marketplace 1.0.6
- September 3, 2018 at 2:32 am #30569
MOHO
ParticipantI try it
http://mall2.sites.moho.tw/store/mohotest3/1. I only could add one slider, can’t add more..
2. I use meta slider free plugin
https://wordpress.org/plugins/ml-slider/and i recommend pc and mobile should use different size slider, it will be good look.
PC: 1500 x 450
Mobile: 600 x 300you could go my site use pc and mobile
https://gspet.avg.gift/thanks.
You must be logged in to view attached files. - September 5, 2018 at 6:27 am #30825
1. Why so? I have just added 3 images – https://ibb.co/mFr1QK
and it’s working perfectly – http://mall2.sites.moho.tw/store/mohotest3/2. I use meta slider free plugin – No additional plugin require for the purpose
PC: 1500 x 450
Mobile: 600 x 300– it’s theme template dependent, you may off course set this sizes from theme CSS file.
- September 8, 2018 at 6:44 am #31147
MOHO
Participant1. Why so? I have just added 3 images
—> it work now2. I use meta slider free plugin – No additional plugin require for the purpose
—> ok greatit’s theme template dependent, you may off course set this sizes from theme CSS file.
ok i got itPlease close it.
- The topic ‘How could add slider post instead of original banner at store vendor page?’ is closed to new replies.
