Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › How could i enable "Manage Stock" and set "Backorders" option?
- This topic has 7 replies, 2 voices, and was last updated 6 years, 11 months ago by
- August 9, 2018 at 1:25 am #27951
MOHO
ParticipantWhen enable “Manage Stock” , then display “Backorders” option in simple and variable product.
But i didn’t want the vendor choose “allow” option.
Could hide “Allow, but notify customer” and “Allow” two options?
The vendor only could choose “Do not Allow” option, thanks
By Moho
You must be logged in to view attached files. - August 9, 2018 at 3:51 pm #28052
You can do this two ways –
1. Using Template Override
2. Using Hooks/FilterKindly check this template for more details – “wc-frontend-manager\views\products-manager\wcfm-view-products-manage-tabs.php”
- August 10, 2018 at 7:48 am #28148
MOHO
ParticipantIf i hide “Backorders” fields,
the value will be “Do not Allow”?if yes, please tell me how to hide this field at simple and variable product.
- August 10, 2018 at 7:50 am #28150
I think no, if you hide this field then it will not take value “Do not Allow”.
Better remove other two options from drop-down.
- August 10, 2018 at 8:46 am #28152
MOHO
ParticipantOK i try now.
Where i should put in child theme?
- August 10, 2018 at 9:50 am #28160
Yeah right.
Copy “wc-frontend-manager\views\products-manager\wcfm-view-products-manage-tabs.php” template to “yourtheme\wcfm\products-manager\wcfm-view-products-manage-tabs.php”
- August 10, 2018 at 11:23 am #28165
MOHO
ParticipantI try, but it no change…
- August 12, 2018 at 4:38 am #28282
Kindly copy this template as well – “wc-frontend-manager\views\products-manager\wcfm-view-products-manage.php”
It’s parent template of that template so it should be there to make those changes working.
- The topic ‘How could i enable "Manage Stock" and set "Backorders" option?’ is closed to new replies.
