Diwali
00Day 19Hr 51Min 45Sec
Diwali
How get custom fields vendor registration to use validation ?
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › How get custom fields vendor registration to use validation ?
Viewing 1 reply thread
    • #128162
      lukas_smith
      I have own fields as HTML with own name
      <input type="text" maxlength="26" id="bank_account-100" name="wcfmvm_custom_infos[bank_account]" onkeypress="return event.charCode >= 48 && event.charCode <= 57" class="wcfm-text" value="" placeholder="" data-required="1" data-required_message="Acc no. this field is req.">
      What i need to do is when i click registration i would add filtr with own function in there for this fields name wcfmvm_custom_infos[bank_account] and calculate is bank acc no is correct? If not return false with message
      Is any way to do this using filter ? i dont wanna change code in core fiels
    • #128367
      Add this js in your theme’s js file –
      jQuery(document).ready(function ($) {
          if($('#wcfm_membership_registration_form #bank_account').length > 0) {
             $( document.body ).on( 'wcfm_form_validate', function( event, validating_form ) {
                $form = $(validating_form);
                $wcfm_is_valid_form = false;
                var is_valid = checkStrength($('#bank_account').val());
                if(is_valid) {
                  $wcfm_is_valid_form = true;
                } else {
                  $('#bank_account').removeClass('wcfm_validation_success').addClass('wcfm_validation_failed');
                  $('#bank_account').addClass('wcfm_validation_failed');
                  $('#wcfm_membership_container .wcfm-message:not(.email_verification_message, .sms_verification_message)').html( '<span class="wcicon-status-cancelled"></span>' + $('#bank_account').data('mismatch_message') ).addClass('wcfm-error').slideDown();
        function checkStrength(accno) {
          if(isNaN(accno)){
            return $wcfm_is_valid_form = false;
          } else {
            return $wcfm_is_valid_form = true;
      And add this code in your theme’s functions.php –
      add_filter( 'wcfm_membership_registration_fields_username', function( $wcfm_register_field ) {
      	$wcfm_register_field["bank_account"] = array( 'label' => __('Bank account', 'wc-multivendor-membership') , 'type' => 'text', 'custom_attributes' => array( 'required' => 1 , 'required_message' => __( 'Acc no. this field is req.', 'wc-multivendor-membership' ),'mismatch_message' => __( 'Invalid Bank Account Number.', 'wc-multivendor-membership' ) ), 'class' => 'wcfm-text wcfm_ele ', 'label_class' => 'wcfm_ele wcfm_title', 'value' => $bank_account );
      	return $wcfm_register_field;
      },15);
  • The topic ‘How get custom fields vendor registration to use validation ?’ is closed to new replies.
